I am coding a filter system for the Outliner. My system uses two “collections” which represent collections of filters and collections of collections of filters. I have modeled my system after the rna(e.g. rna_def_scene_keying_sets()
) and python code for the keying sets in the Properties editor. Man, I have compared, again and again, the keying set code against my code, and they seem to match up/correlate perfectly except for different names.
My first collection’s C struct is called struct TreeFilterList
and it contains a ListBase of my second collection. My second is called struct TreeFilterElement
and it is supposed to hold all the meaningful data used to filter the Outliner. The Python names and C struct names are identical.
My problem is with the Python template_list()
for TreeFilterElement
. The problem is that regardless of which UI list element/list is active, only the last UI list element/list properties’ values(e.g. “labelddd”) can be changed or even shows up in Blender’s UI - even after a refresh. Again, it doesn’t matter which template_list()
element is actually active - only the last element’s data actually appears on screen or can be altered.
Question: Why might the problem, mentioned above, be happening - my collections seem to correlate perfectly with the keying set collections code?
EDIT: I might post some code later if no one has an answer.
