Hi, I want to write a plugin that allows me to procedurally generate a world based on a graph of nodes with xyz positions (i.e. can be place in a scene) as well as some attached metadata (biome information, references to connected nodes, etc), but am already failing with how to model/implement that node graph. The best recommendation I got on IRC was using empties for the nodes, but when I try adding an empty to a scene, I get RuntimeError: Error: ID type 'OBJECT' is not valid for an object
My code currently looks like this:
bl_info = {
"name": "collator",
"author": "phryk",
"version": (0, 0),
"blender": (2, 80, 0),
"location": "View3D > Add > Mesh > New PoI",
"description": "Adds a new Point of Interest",
"warning": "",
"doc_url": "",
"category": "Add Mesh",
import bpy
from bpy.types import Operator
from bpy.props import FloatVectorProperty
from bpy_extras.object_utils import AddObjectHelper, object_data_add
from mathutils import Vector
def add_object(self, context):
poi = bpy.data.objects.new("New Point of Interest", None)
poi.empty_display_type = 'PLAIN_AXES'
poi.location = Vector([0,0,0])
print(dir(poi))
object_data_add(context, poi, operator=self)
class OBJECT_OT_add_object(Operator, AddObjectHelper):
"""Create a new Point of Interest"""
bl_idname = "mesh.add_poi"
bl_label = "Add Point of Interest"
bl_options = {'REGISTER', 'UNDO'}
scale: FloatVectorProperty(
name="scale",
default=(1.0, 1.0, 1.0),
subtype='TRANSLATION',
description="scaling",
def execute(self, context):
return {'FINISHED'}
# Registration
def add_object_button(self, context):
self.layout.operator(
OBJECT_OT_add_object.bl_idname,
text="Point of Interest",
icon='PLUGIN')
# This allows you to right click on a button and link to documentation
def add_object_manual_map():
url_manual_prefix = "https://docs.blender.org/manual/en/latest/"
url_manual_mapping = (
("bpy.ops.mesh.add_object", "scene_layout/object/types.html"),
return url_manual_prefix, url_manual_mapping
def register():
bpy.utils.register_class(OBJECT_OT_add_object)
bpy.utils.register_manual_map(add_object_manual_map)
bpy.types.VIEW3D_MT_mesh_add.append(add_object_button)
def unregister():
bpy.utils.unregister_class(OBJECT_OT_add_object)
bpy.utils.unregister_manual_map(add_object_manual_map)
bpy.types.VIEW3D_MT_mesh_add.remove(add_object_button)
if __name__ == "__main__":
register()
And the generated traceback like this:
Python: Traceback (most recent call last):
File "/home/phryk/devel/gfx/blender/poi.blend/Text", line 45, in execute
File "/home/phryk/devel/gfx/blender/poi.blend/Text", line 27, in add_object
File "/usr/local/share/blender/2.91/scripts/modules/bpy_extras/object_utils.py", line 127, in object_data_add
obj_new = bpy.data.objects.new(name, obdata)
I’m not sure I’m interpreting this right – does this mean adding an empty just isn’t valid? If so, what would be a good fit for an object type to use instead?
