Reason:
The default startup has settings and workspaces generally stored in a startup file, but default load up and factory reset has settings programmatically stored in another C file listed below - of which I’d like to change.
versioning_defaults.c
//source/blender/blenloader/intern
Examples
The C file resets the theme to the blender default, but I’d prefer a personal theme on factory reset:
Task
Re-generate new theme C file. The following file needs to be generated by another file in the repository.
userdef_default_theme.c
Location
\release\datafiles\userdef
By using this file:
blender_update_themes.py
Location
//source/tools/utils/blender_theme_as_c.py
Command
./source/tools/utils/blender_theme_as_c.py ~/.config/bforartists/2.80/config/userpref.blend
But how do I do this? Pardon my noobness. Thanks for any pointers!
