Can you help me @LazyDodo? How to know the different branches of 2.7? and also 2.8?
You can use git branch -a | grep release
to find out all the release branches since v2.79.
Further you can use git tag
to view all tags. All releases have been tagged with the corresponding release number, up until 2.82 with the form vX.YZ
. Check out a tag to get the commit used for release.
Thanks a lot @jesterKing, i tried ur suggestion and here’s the output
For your own fun try also: git tag | grep v2.7.
Okay, Thanks again @jesterKing… So this are all the tags from 2.79 (see attached picture)?ryt?
Can i checkout this tags also using git checkout tag name
The tags you see are for the 2.7x series all the way from v2.70 up to v2.79b.
Yes, for instance git checkout v2.79b
Don’t forget to update all the submodules after checking out:
git submodule update --init --recursive
Thank you thank you so much
