I went ahead and updated the mesh_f2 addon since its a indispensable part of my workflow.
I wanna know if and how can I submit a review for this addon and maybe it get approved, It required verry few changes and from my tests is working perfectly:
# ##### BEGIN GPL LICENSE BLOCK #####
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software Foundation,
# Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# ##### END GPL LICENSE BLOCK #####
# <pep8 compliant>
bl_info = {
"name": "F2",
"author": "Bart Crouch, Alexander Nedovizin, Paul Kotelevets "
"(concept design)",
"version": (1, 7, 2),
"blender": (2, 80, 0),
"location": "Editmode > F",
"warning": "",
"description": "Extends the 'Make Edge/Face' functionality",
"wiki_url": "http://wiki.blender.org/index.php/Extensions:2.6/Py/"
"Scripts/Modeling/F2",
"category": "Mesh",
import bmesh
import bpy
import itertools
import mathutils
from bpy_extras import view3d_utils
# returns a custom data layer of the UV map, or None
def get_uv_layer(ob, bm, mat_index):
if ob.data.uv_layers.active:
return bm.loops.layers.uv.get(ob.data.uv_layers.active.name)
else:
return None
# create a face from a single selected edge
def quad_from_edge(bm, edge_sel, context, event):
ob = context.active_object
region = context.region
region_3d = context.space_data.region_3d
# find linked edges that are open (<2 faces connected) and not part of
# the face the selected edge belongs to
all_edges = [[edge for edge in edge_sel.verts[i].link_edges if \
len(edge.link_faces) < 2 and edge != edge_sel and \
sum([face in edge_sel.link_faces for face in edge.link_faces]) == 0] \
for i in range(2)]
if not all_edges[0] or not all_edges[1]:
return
# determine which edges to use, based on mouse cursor position
mouse_pos = mathutils.Vector([event.mouse_region_x, event.mouse_region_y])
optimal_edges = []
for edges in all_edges:
min_dist = False
for edge in edges:
vert = [vert for vert in edge.verts if not vert.select][0]
world_pos = ob.matrix_world @ vert.co.copy()
screen_pos = view3d_utils.location_3d_to_region_2d(region,
region_3d, world_pos)
dist = (mouse_pos - screen_pos).length
if not min_dist or dist < min_dist[0]:
min_dist = (dist, edge, vert)
optimal_edges.append(min_dist)
# determine the vertices, which make up the quad
v1 = edge_sel.verts[0]
v2 = edge_sel.verts[1]
edge_1 = optimal_edges[0][1]
edge_2 = optimal_edges[1][1]
v3 = optimal_edges[0][2]
v4 = optimal_edges[1][2]
# normal detection
flip_align = True
normal_edge = edge_1
if not normal_edge.link_faces:
normal_edge = edge_2
normal_edge = edge_sel
# no connected faces, so no need to flip the face normal
flip_align = False
if flip_align: # there is a face to which the normal can be aligned
ref_verts = [v for v in normal_edge.link_faces[0].verts]
if v3 in ref_verts:
va_1 = v3
va_2 = v1
elif normal_edge == edge_sel:
va_1 = v1
va_2 = v2
else:
va_1 = v2
va_2 = v4
if (va_1 == ref_verts[0] and va_2 == ref_verts[-1]) or \
(va_2 == ref_verts[0] and va_1 == ref_verts[-1]):
# reference verts are at start and end of the list -> shift list
ref_verts = ref_verts[1:] + [ref_verts[0]]
if ref_verts.index(va_1) > ref_verts.index(va_2):
# connected face has same normal direction, so don't flip
flip_align = False
# material index detection
ref_faces = edge_sel.link_faces
if not ref_faces:
ref_faces = edge_sel.verts[0].link_faces
if not ref_faces:
ref_faces = edge_sel.verts[1].link_faces
if not ref_faces:
mat_index = False
smooth = False
else:
mat_index = ref_faces[0].material_index
smooth = ref_faces[0].smooth
# create quad
try:
if v3 == v4:
# triangle (usually at end of quad-strip
verts = [v3, v1, v2]
else:
# normal face creation
verts = [v3, v1, v2, v4]
if flip_align:
verts.reverse()
face = bm.faces.new(verts)
if mat_index:
face.material_index = mat_index
face.smooth = smooth
except:
# face already exists
return
# change selection
edge_sel.select = False
for vert in edge_sel.verts:
vert.select = False
for edge in face.edges:
if edge.index < 0:
edge.select = True
v3.select = True
v4.select = True
# adjust uv-map
if __name__ != '__main__':
addon_prefs = context.user_preferences.addons[__name__].preferences
if addon_prefs.adjustuv:
bm.edges.index_update()
uv_layer = get_uv_layer(ob, bm, mat_index)
if uv_layer:
uv_ori = {}
for vert in [v1, v2, v3, v4]:
for loop in vert.link_loops:
if loop.face.index > -1:
uv_ori[loop.vert.index] = loop[uv_layer].uv
if len(uv_ori) == 4 or len(uv_ori) == 3:
for loop in face.loops:
try:
loop[uv_layer].uv = uv_ori[loop.vert.index]
except KeyError:
loop[uv_layer].uv = uv_ori[v1.index]
# toggle mode, to force correct drawing
bpy.ops.object.mode_set(mode='OBJECT')
bpy.ops.object.mode_set(mode='EDIT')
# create a face from a single selected vertex, if it is an open vertex
def quad_from_vertex(bm, vert_sel, context, event):
me = ob.data
edges = [edge for edge in vert_sel.link_edges if len(edge.link_faces) < 2]
if len(edges) < 2:
return
min_dist = False
for a, b in itertools.combinations(edges, 2):
other_verts = [vert for edge in [a, b] for vert in edge.verts \
if not vert.select]
mid_other = (other_verts[0].co.copy() + other_verts[1].co.copy()) \
/ 2
new_pos = 2 * (mid_other - vert_sel.co.copy()) + vert_sel.co.copy()
world_pos = ob.matrix_world @ new_pos
screen_pos = view3d_utils.location_3d_to_region_2d(region, region_3d,
world_pos)
min_dist = (dist, (a, b), other_verts, new_pos)
# create vertex at location mirrored in the line, connecting the open edges
edges = min_dist[1]
other_verts = min_dist[2]
new_pos = min_dist[3]
vert_new = bm.verts.new(new_pos)
# normal detection
flip_align = True
normal_edge = edges[0]
normal_edge = edges[1]
flip_align = False
if other_verts[0] in ref_verts:
va_1 = other_verts[0]
va_2 = vert_sel
else:
va_1 = vert_sel
va_2 = other_verts[1]
flip_align = False
ref_faces = vert_sel.link_faces
if not ref_faces:
mat_index = False
smooth = False
else:
# create face between all 4 vertices involved
verts = [other_verts[0], vert_sel, other_verts[1], vert_new]
if flip_align:
verts.reverse()
if mat_index:
# change selection
vert_new.select = True
vert_sel.select = False
# adjust uv-map
if uv_layer:
uv_others = {}
uv_sel = None
uv_new = None
# get original uv coordinates
for i in range(2):
for loop in other_verts[i].link_loops:
uv_others[loop.vert.index] = loop[uv_layer].uv
break
if len(uv_others) == 2:
mid_other = (list(uv_others.values())[0] +
list(uv_others.values())[1]) / 2
for loop in vert_sel.link_loops:
uv_sel = loop[uv_layer].uv
break
if uv_sel:
uv_new = 2 * (mid_other - uv_sel) + uv_sel
# set uv coordinates for new loops
if uv_new:
if loop.vert.index == -1:
x, y = uv_new
elif loop.vert.index in uv_others:
x, y = uv_others[loop.vert.index]
else:
x, y = uv_sel
loop[uv_layer].uv = (x, y)
# autograb preference in addons panel
# noinspection PyStatementEffect
class F2AddonPreferences(bpy.types.AddonPreferences):
bl_idname = __name__
adjustuv : bpy.props.BoolProperty(
name = "Adjust UV",
description = "Automatically update UV unwrapping",
default = True)
autograb : bpy.props.BoolProperty(
name = "Auto Grab",
description = "Automatically puts a newly created vertex in grab mode",
default = False)
def draw(self, context):
layout = self.layout
layout.prop(self, "autograb")
layout.prop(self, "adjustuv")
class MESH_OT_F2(bpy.types.Operator):
"""Tooltip"""
bl_idname = "mesh.f2"
bl_label = "Make Edge/Face"
bl_description = "Extends the 'Make Edge/Face' functionality"
bl_options = {'REGISTER', 'UNDO'}
@classmethod
def poll(cls, context):
# check we are in mesh editmode
return(ob and ob.type == 'MESH' and context.mode == 'EDIT_MESH')
bm = bmesh.from_edit_mesh(context.active_object.data)
sel = [v for v in bm.verts if v.select]
if len(sel) > 2:
# original 'Make Edge/Face' behaviour
try:
bpy.ops.mesh.edge_face_add('INVOKE_DEFAULT')
except:
return {'CANCELLED'}
elif len(sel) == 1:
# single vertex selected -> mirror vertex and create new face
quad_from_vertex(bm, sel[0], context, event)
addon_prefs = context.user_preferences.addons[__name__].\
preferences
if addon_prefs.autograb:
bpy.ops.transform.translate('INVOKE_DEFAULT')
elif len(sel) == 2:
edges_sel = [ed for ed in bm.edges if ed.select]
if len(edges_sel) != 1:
# 2 vertices selected, but not on the same edge
bpy.ops.mesh.edge_face_add()
else:
# single edge selected -> new face from linked open edges
quad_from_edge(bm, edges_sel[0], context, event)
return {'FINISHED'}
# registration
classes = (
MESH_OT_F2,
F2AddonPreferences,
addon_keymaps = []
def register():
# add operator
for c in classes:
bpy.utils.register_class(c)
# add keymap entry
kcfg = bpy.context.window_manager.keyconfigs.addon
if kcfg:
km = kcfg.keymaps.new(name='Mesh', space_type='EMPTY')
kmi = km.keymap_items.new("mesh.f2", 'F', 'PRESS')
addon_keymaps.append((km, kmi))
def unregister():
# remove keymap entry
for km, kmi in addon_keymaps:
km.keymap_items.remove(kmi)
addon_keymaps.clear()
# remove operator and preferences
for c in reversed(classes):
bpy.utils.unregister_class(c)
if __name__ == "__main__":
register()
