does anyone know how to get selected vertices in the UV editor using Python in 3.4? The Python API docs search is so abysmal I’ve just not been able to find the answer whatsoever
In 3.4 you access D.meshes['Cube'].uv_layers['UVMap'].data
Which is an array of the MeshUVLoop type. That contains the selection states. (MeshUVLoop(bpy_struct) — Blender Python API)
In 3.5 there’s this (new, yet to be properly documented) way, because the data is now stored in separate arrays:D.meshes['Cube'].uv_layers['UVMap'].vertex_selection
which returns an array of booleans.
There’s also
D.meshes['Cube'].uv_layers['UVMap'].edge_selection
D.meshes['Cube'].uv_layers['UVMap'].pin
also returning an array of bools.
and of course
D.meshes['Cube'].uv_layers['UVMap'].uv
returning an array of float2 vectors for the uvs themselves.
The older way is (for now) still supported in 3.5, but rather a lot slower because the MLoopUV structure needs to be re-created from the internal arrays, while the direct array access just directly return the data.
