My addon relies on checking bpy.data.is_dirty
. This seems to work fine in interactive mode, however when I tried adding automated tests for my addon I have faced issue with bpy.data.is_dirty
not updating correctly when things are getting changed from my tests (Python script).
Example script to reproduce (on Blender 2.79):
>>> bpy.data.scenes[0].frame_start = bpy.data.scenes[0].frame_start + 1
>>> bpy.data.is_dirty
False
I can see starting frame change on the timeline, however there is no asterisk “*” visible in title (which generally indicates unsaved changes).
If I change starting frame by clicking on small arrow by number it marks the file correctly as changed (both the asterisk appears and bpy.data.is_dirty
returns `True).
I have also managed to get a state in tests that have bpy.data.is_dirty
returns True
even on the next line just after call to bpy.ops.wm.save_mainfile()
Is there some function I need to call to get Blender’s internal state to update bpy.data.is_dirty
Alternatively, as I need it only for tests, is there some way to make sure that bpy.data.is_dirty
is in a desired state? (i.e. I need to be able to set it both to True
and False
depending on scenario)
I read https://docs.blender.org/api/2.79/info_gotcha.html#no-updates-after-setting-values and tried using bpy.context.scene.update()
, but it doesn’t seem to impact bpy.data.is_dirty
Note: this is clone of my question on blender.stackexchange
