I’m trying to create an Eclipse project for Blender so I can use the really awesome callgraph feature(or addon, I don’t remember which) that I saw on the internet.
I’m using Windows 10, CMake, and MinGW. Within CMake I’m using the “Eclipse CDT4 - MinGW Makefiles” generator
I’ve tried to configure project files but I get this error:
The C compiler identification is GNU 8.2.0
The CXX compiler identification is GNU 8.2.0
Could not determine Eclipse version, assuming at least 3.6 (Helios). Adjust CMAKE_ECLIPSE_VERSION if this is wrong.
Check for working C compiler: C:/MinGW/bin/gcc.exe
Check for working C compiler: C:/MinGW/bin/gcc.exe -- works
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Detecting C compile features
Detecting C compile features - done
Check for working CXX compiler: C:/MinGW/bin/g++.exe
Check for working CXX compiler: C:/MinGW/bin/g++.exe -- works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Detecting CXX compile features
Detecting CXX compile features - done
Performing Test SUPPORT_SSE_BUILD
Performing Test SUPPORT_SSE_BUILD - Failed
SSE Support: missing.
Performing Test SUPPORT_SSE2_BUILD
Performing Test SUPPORT_SSE2_BUILD - Failed
SSE2 Support: missing.
Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.20.1.windows.1")
CMake Error at build_files/cmake/platform/platform_win32.cmake:29 (message):
Compiler is unsupported
Call Stack (most recent call first):
CMakeLists.txt:886 (include)
Btw, I took out C:\MinGW\msys\1.0\bin\sh.exe because CMake complained about it (I don’t know what I’m doing).
I, at least, would like some project files to allow me to browse the code, but it would be nice to build Blender with Eclipse also.
How do I create Eclipse project files ?
Also, I’ve installed the callgraph plugin that you get through the Marketplace Wizard, and it’s not showing up in the Profiling Tools menu or anywhere that I can see. Would anyone happen to know how to get the call graph to work?
