When I compile blender, I can create a new default startup.blend file that stores preferences, technically. But unfortunately I’ve found that a factory reset will crash because a particular addon is no-longer saved as activated (something I as an addon to need to run the layout modifications). Now on factory reset and fresh install I get an EXCEPTION_ACCESS_VIOLATION
How can I access the default user preferences for all factory resets before compilation to make sure the settings are correct?
Does a factory reset draw it’s user preferences from the Startup.blend file in the respository \release\datafiles? Or are they somewhere else? (file works fine alone)
I assume the factory userpref.blend settings or parameters are stored elsewhere before compiling. Any idea?
I tried recreating the workspaces on a bare minimum to test the addon, it’s not the cause. I have found that some preferences save to the factory setup, meanwhile others do not. No matter if I compile with a working startup.blend file with the right theme and settings.
The default layout and user preferences are stored in release/datafiles/startup.blend. But there are a bunch of settings that are changed programmatically on top of that, mainly in versioning_defaults.c.
