The following is the code that changes the name of the particle and its corresponding modifier, but only the name of the particle. How can I change the code so that the input changes both names
import bpy
class WM_OT_PMRename(bpy.types.Panel):
bl_space_type = 'TOPBAR' # dummy
bl_region_type = 'HEADER'
bl_label = "Particle and Modifiers name"
bl_ui_units_x = 14
def draw(self, context):
selected_index = bpy.context.object.particle_systems.active_index
selected_name = bpy.context.object.particle_systems[selected_index].name
layout = self.layout
item = bpy.context.object.particle_systems[selected_index]
if item:
layout.label(text="Particle and Modifiers name")
row = layout.row()
row.activate_init = True
row.label(icon='PARTICLES')
row.prop(item, "name", text="")
bpy.context.object.modifiers[selected_name].name = text
def register():
bpy.utils.register_class(WM_OT_PMRename)
def unregister():
bpy.utils.unregister_class(WM_OT_PMRename)
