Hello all
I try to build blender with oidn with Nvidia gpu support.
This is my building scripts (gentoo)
Thank you for advice!
Hello all
These are Gentoo specific builds which not many developers are familiar with or can easily test themselves, so not likely to get a response.
In general to help getting this solved:
include/OpenImageDenoise/config.h
to verify supported device types are enabledHi,
Tank you for answer!
oidn package builds with -DOIDN_DEVICE_CUDA=ON and cuda targets sm_86 for 3080
oidn package has /usr/lib64/libOpenImageDenoise_device_cuda.so.2.2.2 and /usr/include/OpenImageDenoise/config.h installed
blender compiled with cuda and optix? and it works fine.
What thing i missed?
blender --debug-cycles --verbose 10
trying to render with OIDN GPU supportThis is my /usr/include/OpenImageDenoise/config.h
https://bpa.st/AMTQ
I open blender and turn on oidn gpu checkbox
$ blender --debug-cycles --verbose 10
INFO:cg_preferences:Register CG Preferences!
INFO:cg_preferences:Checking preferences ...
INFO:cg_preferences:No new version was found!
I20240604 17:13:43.901419 70594 device.cpp:36] CUEW initialization succeeded
I20240604 17:13:43.902469 70594 device.cpp:42] Found CUDA compiler nvcc
I20240604 17:13:43.919731 70594 denoiser_oidn_gpu.cpp:70] Checking device NVIDIA GeForce RTX 3080 Laptop GPU (CUDA_NVIDIA GeForce RTX 3080 Laptop GPU_0000:01:00) for OIDN GPU support
I20240604 17:13:43.920310 70594 denoiser_oidn_gpu.cpp:120] Found 1 OIDN device(s)
I20240604 17:13:43.920323 70594 denoiser_oidn_gpu.cpp:124] OIDN device 0: name="11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz" type=CPU
I20240604 17:13:43.920329 70594 denoiser_oidn_gpu.cpp:143] No matched OIDN device found
after render log
https://bpa.st/DGEA
Does a build downloaded from blender.org work? It’s seeming less like a build problem, at least I don’t have a good guess for it.
Perhaps OIDN has an issue finding the CUDA shared library on the system. Blender uses dlopen to load it at runtime, while OIDN links against it directly.
You could attach the out of running LD_DEBUG=libs blender
and trying to rendering with OIDN GPU. The log might show it can’t find some CUDA library.
Thank you!
Looks like we found a problem
I run blender as:
and get log woth this errors:
80696: /usr/lib64/libOpenImageDenoise_device_cuda.so.2.2.2: error: symbol lookup error: undefined symbol: _ZN4oidn23getCutlassConvInstancesILi70EEESt6vectorINS_18CutlassConvFactoryESaIS2_EEv (fatal)
80696: /usr/lib64/libnvidia-glcore.so.550.78: error: symbol lookup error: undefined symbol: __malloc_hook (fatal)
I think problem is somwhere in my system toolchain
I will report if i found a way!
