Hey,
I wanted to ask if there is an alternative to the operator bpy.ops.dpaint.type_toggle(type=‘BRUSH’) to add the brush to the object. The following code is intended to simply apply dynamic paint to a lot of objects, set type to brush and add/toggle the brush. Then set a value to test whether the brush was added correctly and the paint source could set. It works nicely for one object, but for several the behaviour seems erratic. Most of the time it works for one or 2 of the selected obejcts at the first or second try. What am I doing wrong and can improve?
thx in advance
` import bpy`
data = bpy.data
context = bpy.context
active = context.active_object
selobj = context.selected_objects[:]
def addDynBrush():
a=0
for obj in selobj:
a += 1
print("Round " + str(a))
active = obj
obj.modifiers.new(name='Dynamic Paint', type='DYNAMIC_PAINT') ### add dynamic paint
obj.modifiers['Dynamic Paint'].ui_type = 'BRUSH' ### change type to brush
bpy.ops.dpaint.type_toggle(type='BRUSH') ### add/toggle the brush
#bpy.ops.dpaint.type_toggle(type='BRUSH') ### add/toggle the brush
try:
obj.modifiers['Dynamic Paint'].brush_settings.paint_source = 'VOLUME_DISTANCE' ####test wheater the brush is there
except:
print("This one didn't work!!!! Objectname = " + str(obj.name)) ##### result for the console
bpy.ops.dpaint.type_toggle(type='BRUSH') ### add the brush again!!!!!
try:
except:
def removeDynBrush():
a = 0
for obj in selobj:
a += 1
if "Dynamic Paint" in obj.modifiers:
obj.modifiers.remove(obj.modifiers['Dynamic Paint'])
addDynBrush() # adds Dynamic Paint Brushes from all selected
#removeDynBrush() # removes Dynamic Paint Brushes from all selected use for reseting your test file while blocking the upper function
