I am trying to use a script to add some rules to the boid brain of a particle system and the operators on website here, https://docs.blender.org/api/current/bpy.ops.boid.html, don’t seem to be doing anything. Does anyone know a way to do add various rules to a boid brain system via script?
I am using the following code to add the particle system to an existing selected object in the scene. Everything works up until the last line where I try to add the Boid rule. That line doesn’t seem to do anything to the particle system.
#adding particle system with custom particle system settings
obj = bpy.context.active_object
if len(obj.particle_systems) == 0:
obj.modifiers.new("part", type='PARTICLE_SYSTEM')
part = obj.particle_systems[0]
settings = part.settings
settings.name = 'Bug System'
settings.count = 1000
settings.frame_start = 1
settings.frame_end = (250)
settings.lifetime = 500
settings.lifetime_random = 0
settings.emit_from = 'FACE'
settings.physics_type = 'BOIDS'
bpy.context.object.show_instancer_for_render = False
settings.show_unborn = True
settings.use_dead = True
settings.render_type = 'COLLECTION'
settings.particle_size = 0.05
settings.size_random = 0.3
bpy.data.particles["Bug System"].instance_collection = bpy.data.collections[context.scene.spyderfy_tool.my_stringbugsystem]
settings.show_unborn = False
settings.use_dead = False
settings.jitter_factor = 0
settings.object_factor = 1
settings.effector_weights.turbulence = 0
#adding boid brain rules in correct order
bpy.ops.boid.rule_add(type='FLOCK') #This is the one that doesn't seem to be working.
return{'FINISHED'}
