In Blender 2.79 it was possible to get access to a list of uv coordinates via “tessface_uv_textures”
Now they are only listed as single loops in “uv_layers”. Is there a way to recreate this uv list for the loops of triangles? or is the only way to access them via polygons. I need a formular to get 6 UVs for the 3 points of a triangle.
Hope I descriped the problem properly - I am just new here
There is an example of how to print the UVs for every polygon in the docs:
https://docs.blender.org/api/master/bpy.types.Mesh.html
@brecht thanks for fast reply - I have seen that, but how to get especially the UVs, wich are associated to the loops of a triangle calculated with the calc_loop_triangles method?
This property has the loop indices that are like loop_index
in the example code.
https://docs.blender.org/api/master/bpy.types.MeshLoopTriangle.html#bpy.types.MeshLoopTriangle.loops
okay this makes sense, but there is a little difference - polygons have loop_start
and loop_total
and meshlooptriangle has only loop
I am very new to python scripting, thats why this may be a noob question. How would the code look like, I guess it would be like:
tri = mesh.loop_triangles
for loop_index in (tri.loop):
print(" UV: %r" % uv_layer[loop_index].uv)
update: I got it to work, thanks again
here is the code:
import bpy
me = bpy.context.object.data
me.calc_loop_triangles()
uv_layer = me.uv_layers.active.data
for tri in me.loop_triangles:
print("Tri index: %d" % (tri.index))
for loop_index in (tri.loops):
