Apologies if this is not the correct place.
I have searched widely and asked on different community forums, but sadly no answer yet. Hoping to reach some Cycles wizards here.
I am trying to rebuild light passes into a combined pass. It works fine until I render with AO/GI. You can see the difference in results below:
Node setup
Combined Pass - AO off
Rebuild Composite - AO off
Combined Pass - AO on
Rebuild Composite - AO on
Since the manual doesn’t explain much about AO, I thought maybe this info could be added? Or at least a note or tip mentioning this.
