How do I make smaller-resolution renderings appear in the center of the frame buffer?
params.use_resolution_divider = true makes it render smaller-resolution images first.
However, the smaller-resolution images will appear at the bottom of the frame buffer, for example, 8 small ones in a row at the bottom.
It will be better to show 1 small image at the center or make the 1 small image fill the whole frame buffer?
Looks can be done by setting viewport.
Thanks.
