Here is to get an idea.
I have not tried to follow the GUI design literally, only to show the example.
Also the part for making the calculator work is another topic.
You would just use eval
and have it work in a snap.
https://realpython.com/python-eval-function/
import bpy
class SimpleOperator(bpy.types.Operator):
"""Tooltip"""
bl_idname = "scene.simple_operator"
bl_label = "Simple Operator"
bl_context = "scene"
bl_options = {"INTERNAL"}
option : bpy.props.StringProperty(name='option')
buffer : bpy.props.StringProperty(name='result')
def execute(self, context):
print('option',self.option)
if self.option == 'c':
self.buffer = ''
else:
self.buffer += self.option
print('buffer',self.buffer)
return {'FINISHED'}
class LayoutDemoPanel(bpy.types.Panel):
"""Creates a Panel in the scene context of the properties editor"""
bl_label = "Layout Demo"
bl_idname = "SCENE_PT_layout"
bl_space_type = 'PROPERTIES'
bl_region_type = 'WINDOW'
def op(self, layout, value):
layout.operator("scene.simple_operator", text=value).option=value
def draw(self, context):
layout = self.layout
# to create three horizontal rows
col = layout.column(align=True)
# to create three vertical columns
row = col.row(align=True)
self.op(row, "1")
self.op(row, "2")
self.op(row, "3")
self.op(row, "4")
self.op(row, "5")
self.op(row, "6")
self.op(row, "7")
self.op(row, "8")
self.op(row, "9")
self.op(row, "0")
# to create actions
row = layout.row(align=True)
self.op(row, "=")
self.op(row, "+")
self.op(row, "-")
self.op(row, "*")
self.op(row, "/")
self.op(row, "c")
def register():
bpy.utils.register_class(LayoutDemoPanel)
bpy.utils.register_class(SimpleOperator)
def unregister():
bpy.utils.unregister_class(SimpleOperator)
bpy.utils.unregister_class(LayoutDemoPanel)
if __name__ == "__main__":
register()
