I am trying to host Cycles inside my application. It is a C++ application. I am importing a fbx file using FbxSdk and building Cycles scene. I am able to build Cycles scene and render. The only problem is I could not calculate transforms properly. I could not understand how Blender is calculating global transform. I don’t know python. Can you please help me in this?
In my code, I simply did FbxAxisSystem::MayaZUp.ConvertScene(fbx_scene);
But still the transformations are different from what blender is calculating.
The below is the code from blender. I could understand it upto some extent but i could not understand the method axis_conversion.
Thanks in advance.
unit_scale = elem_props_get_number(fbx_settings_props, b'UnitScaleFactor', 1.0)
unit_scale_org = elem_props_get_number(fbx_settings_props, b'OriginalUnitScaleFactor', 1.0)
global_scale *= (unit_scale / units_blender_to_fbx_factor(context.scene))
# Compute global matrix and scale.
if not use_manual_orientation:
axis_forward = (elem_props_get_integer(fbx_settings_props, b'FrontAxis', 1),
elem_props_get_integer(fbx_settings_props, b'FrontAxisSign', 1))
axis_up = (elem_props_get_integer(fbx_settings_props, b'UpAxis', 2),
elem_props_get_integer(fbx_settings_props, b'UpAxisSign', 1))
axis_coord = (elem_props_get_integer(fbx_settings_props, b'CoordAxis', 0),
elem_props_get_integer(fbx_settings_props, b'CoordAxisSign', 1))
axis_key = (axis_up, axis_forward, axis_coord)
axis_up, axis_forward = {v: k for k, v in RIGHT_HAND_AXES.items()}.get(axis_key, ('Z', 'Y'))
global_matrix = (Matrix.Scale(global_scale, 4) @ axis_conversion(from_forward=axis_forward, from_up=axis_up).to_4x4())
def axis_conversion(from_forward='Y', from_up='Z', to_forward='Y', to_up='Z'):
Each argument us an axis in ['X', 'Y', 'Z', '-X', '-Y', '-Z']
where the first 2 are a source and the second 2 are the target.
from mathutils import Matrix
from functools import reduce
if from_forward == to_forward and from_up == to_up:
return Matrix().to_3x3()
if from_forward[-1] == from_up[-1] or to_forward[-1] == to_up[-1]:
raise Exception("Invalid axis arguments passed, "
"can't use up/forward on the same axis")
value = reduce(int.__or__, (_axis_convert_num[a] << (i * 3)
for i, a in enumerate((from_forward,
from_up,
to_forward,
to_up,
for i, axis_lut in enumerate(_axis_convert_lut):
if value in axis_lut:
return Matrix(_axis_convert_matrix[i])
assert(0)
