I am trying to set HDR image background for my scene.
I am expecting a colorful forest as my background but I am getting full white background.
The below is my code. I tried setting the HDR image in blender and did debugging the blender sync code to check how the shaders are populated. I did exactly the same how blender is doing but could not understand what went wrong.
Can you please throw some light?
Thanks in advance.
void set_image_background(Scene& scene)
Background *background = scene.background;
background->ao_factor = 1;
background->ao_distance = 10;
background->use_shader = true;
background->use_ao = false;
background->visibility = 4125;
background->transparent = false;
background->transparent_glass = false;
background->transparent_roughness_threshold = 0;
background->need_update = true;
populate_background_shader(*scene.default_background,"c:\\imp\\hdr\\forest.hdr");
scene.default_background->tag_update(&scene);
void populate_background_shader(Shader &shader, const std::string &hdr_image_path)
ShaderGraph *graph = new ShaderGraph();
EnvironmentTextureNode *environment_texture_node = new EnvironmentTextureNode();
environment_texture_node->builtin_data = nullptr;
environment_texture_node->filename = hdr_image_path;
environment_texture_node->colorspace = ustring("Linear");
environment_texture_node->animated = false;
environment_texture_node->alpha_type = ImageAlphaType::IMAGE_ALPHA_ASSOCIATED;
environment_texture_node->interpolation = InterpolationType::INTERPOLATION_LINEAR;
environment_texture_node->projection =
NodeEnvironmentProjection::NODE_ENVIRONMENT_EQUIRECTANGULAR;
environment_texture_node->bump = ShaderBump::SHADER_BUMP_NONE;
graph->add(environment_texture_node);
BackgroundNode *background_node = new BackgroundNode();
background_node->color = make_float3(0.0508760884);
background_node->strength = 1;
background_node->surface_mix_weight = 1;
graph->add(background_node);
OutputNode *output_node = graph->output();
graph->connect(environment_texture_node->output("Color"), background_node->input("Color"));
graph->connect(background_node->output("Background"), output_node->input("Surface"));
shader.graph = graph;
shader.has_surface = true;
shader.use_mis = true;
shader.use_transparent_shadow = true;
shader.heterogeneous_volume = true;
shader.need_update = true;
shader.has_surface_emission = false;
shader.has_surface_transparent = false;
