Report week 7
This week has been productive for me, and I’ve been able to spend many hours on the project.
This week challenges:
I wanted to rebase my working branch on the latest main after the merge of a patch I did on the main branch. This put all the new commits as mine in the PR, which showed a change of hundreds of files.
What I did to fix this was first to extract my precious diff
git diff > my_patch.txt
and then force pull my main branch from the origin.What to learn from this ?
NEVER work on the main branch even locally, keep it in sync with the origin main branch. This way the diff between a branch and the main is always what we want.
It is probably not what people would recommend, but it will avoid me many errors and problems.
I did:
- put the preview resolution in the parameters
- change compositor previews to use ImBuf. PR
- prepare a patch for imbuf support for shader node previews (on my computer for now)
- some cleaning and renaming in the main PR (which changed due to a git issue on my side btw).
- publish a PR for a bug I introduced about overlay hiding Bug Report
Todo next week:
- try to have the compositor transition to ImBuf merged
- then adapt the ImBuf previews to the main PR (use the patch I already prepared)
- then put a background for AOV nodes
- fix some minor issues listed here
Little demo
Approximative time spent on XCode: 16.5hrs.
Total time on dev(XCode, debugging, blender websites, git, blender program): 30hrs.
