GSoC 2022: Many Lights Sampling in Cycles X (Weekly Report)
Weekly Report #7 (7/25-7/31):
This week, I talked with Brecht about the issues that were mentioned in the feedback thread. The proposed solution was to implement our own version of adaptive splitting, which I’ve begun working on. My current implementation uses a stack to keep track of the splitting, and weighted reservoir sampling to handle the stream of candidate samples.
Right now, the “weighting” is just sampling the candidates uniformly, so I don’t expect it to work well on some of the scenes that have been previously tested. However, even this initial solution seems promising for some issues from the feedback thread. These two renders were rendered at 16 samples:
Large Spotlight Radius:
Area Light Spread:
There’s still noticeable noise but I suspect that it will be much better once we use proper weighting for the candidates. The idea, for now, is to potentially take an actual light sample to perform the weighting. I’d also like to see if visibility can be included.
Overall, Brecht and I also discussed that a stable and refined implementation of surface sampling should take priority. As such, I’ll likely dedicate the remaining weeks of GSoC towards stabilizing and optimizing this new technique. The volume support may have to come later, e.g. over the winter.
Objective for Week #8:
I’d like to complete the following for next week:
  • Implement a better weighting calculation for the reservoir sampling.
    • I’d like to first use a light sample, and then see if visibility can also be incorporated.
  • Investigate how to calculate the PDF for multiple importance sampling
Since this new algorithm did require some restructuring of the code, I suspect that a few things will be breaking in the near future. For those testing things out, please continue to let me know of any issues in the feedback thread! The reports are helping a lot in terms of debugging, etc.
