Yes. THAT one really hurt. UV algorithms are such a fundamental feature in any 3D software. Ever since I saw that video nearly five years ago, now I was hyped for it. After a year I kinda started losing hope. After two years I had forgotten about it.
A quick update :
As @testure pointed out, there are addons that implment the ideas for straightening UVs, I have updated the proposal with some new ideas based on the initial feedback.
In particular I found that there are some features that could be implemented for improving workflows that involve working with UDIM textures in the UV editor (based on the suggestion by @RonanDucluzeau)
The new ideas are listed below and also updated in the draft (original post in this topic).
- Packing to user specified UDIM tiles
- Add feature for dynamic grid and grid snapping to the UV editor
- Features to simplify moving UVs across UDIM tiles
Refer to the draft (original post) for detailed description of these ideas
@jacek007g thereās a similar task created here - T78400.
I think this would be a nice feature to support. I have updated the proposal to include a few secondary tasks during the community boding period and I will try adding it to that list.
I will be working on those tasks during the final weeks of GSoC and after the program as well. Note that the secondary tasks wonāt be the primary focus of GSoC, so I will start working on them after the primary deliverables have been completed
The pattern checker however, I feel is out of scope.
Hey @mattli911 ! The RCS post did come up many times when I was looking for ideas to include for the proposal.
I feel this task would be better suited for a more experienced developer. I started contributing to Blender about a month ago, so Iām still working on learning more about the code-base. I may look into this after GSoC, but again Iāll try to not make any false promises, since Iām moving to my final year next semester and I may not have much time to work on any big tasks.
Hi @Eneen!
I donāt plan on including overlap check tool since I believe there are addons that already implement this feature
they are, but you could add small UI tweak using existing code (from MagicUV for example) and improve it to be permanent monitoring for Overlaps or Mirrored UV islands there
as a checkbox, like a āDisplay Stretchā checkbox do or as a radiobutton (Stretch/Overlap/Mirrored one of this stage).
Itās just a suggestion. I do not insist.
I havenāt used the addon yet so Iāll have to take a look into that. If itās feasible then Iāll ask devs on blender.chat about creating a design task for it.
Iām actually running a bit busy with college work since the past few days so it might take a while.
Could be possible add selections tools that allow to select all uv vertex in all X or Y range. Like a classic box select tool but that one of the axis are infinite
Seems doable, since it would be simple variation of the existing UV_OT_select_box
operator, but I canāt think of any uses cases where this tool would be required.
@Alberto Did you encounter the need for this tool in any specific case you were working on?
Totally. Because I work constantly with UVs out of 0-1 range and hard to select
and I think that a tool that allow me to select all vertex out of my screen will allow me to work easily
And actually in assets for game that work with trim textures it is 30% por the workflow.
Thanks for the suggestion @Alberto
I think this can be implemented as a secondary task during the GSoC period and Iāll definitely add this to the list.
Secondary tasks mentioned in my proposal is a list of user suggested improvements that I plan to work on during weeks 8-9 of the coding period.
