I am working on it. Progress is slow because I can only do this in my spare time. But hope to have it merged for release 3.0 in July (it will likely be ready much earlier than that, and in master, but we are too close to the “no new features” day for the 2.93 release).
I am curious what things to be sure to test. I imagine at least somebody cares about using OBJ to transfer to and/or from the other major 3D apps: Maya, 3DS Max, Houdini, Cinema4D, Modo, ZBrush, Lightwave. (Which have I missed that you want to interchange OBJ with?)
And I guess various web repositories of models are in OBJ.
Any hints as to where to find test files exported from each of these apps would be appreciated.
It was moved to 3.1 because I hadn’t made sufficient progress in thoroughly testing and fixing it. Now that bcon2 for 3.0 has been extended a week, there is a chance that I might get the exporter ready in time for the 3.0 cutoff; but not the importer, which I haven’t looked at at all yet.
I made a buildbot build of the current state of the branch, so you can download the thing labeled “Blender 3.0.0-soc-2020-io-performance” from Blender Builds - blender.org
Hi. I’m trying to import a heavy(4.4GB) .obj file exported from Cinema 4D. With blender 3.1.1 Alpha it can’t import, it crashes during import operation. I tried this branch build from buildbot and I’m facing the same problem. It starts the import operation but after some time it crashes. My system have 32GB of RAM an when blender eat 31GB of my RAM it crashes (even my Gnome section restarts…)
I tried a software called MeshLab and it imports the same file very fast without issues, the only problem is that it imports the whole scene a single object…
Is there a plan to deal with that memory issue? Sorry, I didn’t follow this development, not sure if it was mentioned before…
Yes, due to lack for of low-level import code, it will be quite hard to import this size of file. I would suggest you break down your scene into importing multiple files that are smaller in size. Your chance of successful import would be much higher.
