In the scope of issue T97477, GPlayers shall be displayed as channels in the main DopeSheet and Timeline.
I’m trying to fix keyframe selection in this context so that summary selection takes into account channels that are GPLayers.
The problem
I want to adapt the following functions, with they gplayer specific selection function :
[1] act_keys_mselect_single
| ED_gpencil_layer_select_frame
(action_select.c:1536)
[2] act_keys_mselect_channel_only
| ED_gpencil_layer_select_frames
(action_select.c:1645)
[3] box_select_elem
| ED_gpencil_layer_frames_select_region
(action_select.c:380)
[4] region_select_elem
| ED_gpencil_layer_frames_select_box
(action_select.c:627)
The code of all these function share a similar pattern :
action_select.c:[1536|1645|380|627]
/* select the nominated keyframe on the given frame */
if (ale->type == ANIMTYPE_GPLAYER) {
<ED_gpencil_specific_function>
ale->update |= ANIM_UPDATE_DEPS;
else if (ale->type == ANIMTYPE_MASKLAYER) {
<ED_mask_specific_function>
else {
if (ELEM(ac->datatype, ANIMCONT_GPENCIL, ANIMCONT_MASK) && (ale->type == ANIMTYPE_SUMMARY) &&
(ale->datatype == ALE_ALL)) {
ListBase anim_data = {NULL, NULL};
int filter;
filter = (ANIMFILTER_DATA_VISIBLE | ANIMFILTER_LIST_VISIBLE /*| ANIMFILTER_CURVESONLY */ |
ANIMFILTER_NODUPLIS);
ANIM_animdata_filter(ac, &anim_data, filter, ac->data, ac->datatype);
for (ale = anim_data.first; ale; ale = ale->next) {
ANIM_animdata_update(ac, &anim_data);
ANIM_animdata_freelist(&anim_data);
else {
ANIM_animchannel_keyframes_loop(&ked, ac->ads, ale, ok_cb, select_cb, NULL);
This code takes into account selection of single gplayer channels, single masklayer channels, or summaries in the scope of GPencil DopeSheet, but not gplayers channels in summaries of the main dopesheet.
and
keyframes_edit.c:362
short ANIM_animchannel_keyframes_loop(KeyframeEditData *ked,
bDopeSheet *ads,
bAnimListElem *ale,
KeyframeEditFunc key_ok,
KeyframeEditFunc key_cb,
FcuEditFunc fcu_cb)
/* sanity checks */
if (ale == NULL) {
return 0;
/* method to use depends on the type of keyframe data */
switch (ale->datatype) {
/* direct keyframe data (these loops are exposed) */
case ALE_FCURVE: /* F-Curve */
return ANIM_fcurve_keyframes_loop(ked, ale->key_data, key_ok, key_cb, fcu_cb);
/* indirect 'summaries' (these are not exposed directly)
* NOTE: must keep this code in sync with the drawing code and also the filtering code!
case ALE_GROUP: /* action group */
return agrp_keyframes_loop(ked, (bActionGroup *)ale->data, key_ok, key_cb, fcu_cb);
case ALE_ACT: /* action */
return act_keyframes_loop(ked, (bAction *)ale->key_data, key_ok, key_cb, fcu_cb);
case ALE_OB: /* object */
return ob_keyframes_loop(ked, ads, (Object *)ale->key_data, key_ok, key_cb, fcu_cb);
case ALE_SCE: /* scene */
return scene_keyframes_loop(ked, ads, (Scene *)ale->data, key_ok, key_cb, fcu_cb);
case ALE_ALL: /* 'all' (DopeSheet summary) */
return summary_keyframes_loop(ked, (bAnimContext *)ale->data, key_ok, key_cb, fcu_cb);
return 0;
keyframes_edit.c:289
/* This function is used to loop over the keyframe data in a DopeSheet summary */
static short summary_keyframes_loop(KeyframeEditData *ked,
bAnimContext *ac,
FcuEditFunc fcu_cb)
/* loop through each F-Curve, working on the keyframes until the first curve aborts */
case ALE_MASKLAY:
case ALE_GPFRAME:
break;
case ALE_FCURVE:
default: {
ret_code = ANIM_fcurve_keyframes_loop(ked, ale->data, key_ok, key_cb, fcu_cb);
if (ret_code) {
break;
return ret_code;
Possible solutions
To account for gplayers in dopesheet + gain some readability, my idea is to get to something like this :
(use same loop for all channel and dopesheet types)
and
bDopeSheet *ads,
bAnimListElem *ale,
FcuEditFunc fcu_cb)
case ALE_MASKLAY:
return ANIM_masklay_keyframes_loop(ked, ale->key_data, key_ok, key_cb, fcu_cb);
case ALE_GPFRAME:
return ANIM_gplay_keyframes_loop(ked, ale->key_data, key_ok, key_cb, fcu_cb);
return 0;
bAnimContext *ac,
FcuEditFunc fcu_cb)
case ALE_MASKLAY:
ret_code = ANIM_masklay_keyframes_loop(ked, ale->key_data, key_ok, key_cb, fcu_cb);
break;
case ALE_GPFRAME:
ret_code = ANIM_gplay_keyframes_loop(ked, ale->key_data, key_ok, key_cb, fcu_cb);
break;
case ALE_FCURVE:
default: {
break;
if (ret_code) {
break;
return ret_code;
This would imply that ANIM_masklay_keyframes_loop
and ANIM_gplay_keyframes_loop
implement all selection functions listed above, based on the KeyframeEditData and the callbacks passed in parameters.
For example it could be something like :
OPTION 1
bool ANIM_gplay_keyframes_loop(bGPDlayer *gpl,
bool (*gpf_ok)(bGPDframe *, KeyframeEditData *),
bool (*gpf_cb)(bGPDframe *, KeyframeEditData *))
/* error checker */
if (gpl == NULL) {
return false;
/* do loop */
LISTBASE_FOREACH (bGPDframe *, gpf, &gpl->frames) {
/* filter frames */
if (gpf_ok(gpf, ked)) {
gpf_cb(gpf, ked);
/* nothing to return */
return false;
where the callbacks would be :
gpf_ok for [1] : return gpf->framenum == ked->f1
gpf_cb for [1] : gpencil_frame_select(gpf, select_mode);
gpf_ok for [2] : return true
gpf_cb for [2] : gpencil_frame_select(gpf, select_mode);
gpf_ok for [3] :
float pt[2] = {0};
pt[0] = gpf->framenum;
pt[1] = ked->channel_y;
return ( (tool == BEZT_OK_CHANNEL_LASSO) && (keyframe_region_lasso_test(ked->data, pt))
|| (tool == BEZT_OK_CHANNEL_CIRCLE) && (keyframe_region_circle_test(ked->data,pt))
gpf_cb for [3] : gpencil_frame_select(gpf, select_mode);
gpf_ok for [4] : return IN_RANGE(gpf->framenum, ked->f1, ked->f2)
gpf_cb for [4] : gpencil_frame_select(gpf, select_mode);
Given the actual callbacks, the loop function could also be something like this :
OPTION 2
eEditKeyframes_Select select_mode,
eEditKeyframes_Validate tool)
/* error checker */
if (gpl == NULL) {
return false;
/* do loop */
float pt[2] = {0};
bool gpf_ok = ((tool == BEZT_OK_FRAME) && (gpf->framenum == ked->f1)) ;
gpf_ok = gpf_ok || ((tool == BEZT_OK_FRAMERANGE) && (IN_RANGE(gpf->framenum, ked->f1, ked->f2)));
gpf_ok = gpf_ok || ((tool == BEZT_OK_CHANNEL_LASSO) && (keyframe_region_lasso_test(ked->data, pt)) ;
gpf_ok = gpf_ok || ((tool == BEZT_OK_CHANNEL_CIRCLE) && (keyframe_region_circle_test(ked->data,pt));
/* filter frames */
if (gpf_ok){
return false;
The boolean computation could also be donne with a switch statement. Either way, may not be very good for performances.
Maybe a good compromise would be :
OPTION 3
bool (*gpf_ok)(bGPDframe *, KeyframeEditData *))
/* error checker */
if (gpl == NULL) {
return false;
/* do loop */
/* filter frames */
if (gpf_ok(gpf, ked)){
return false;
I am also open to hear your opinion on
OPTION 4
Do something completely different
My questions
First, what do you think about this issue, what would be the best option ?
Thing is, to implement this properly, I’d have to make code changes in both Gpencil and Animation parts :
- the two last parameters (select_mode and (tool or gpf_ok)) have to be added to both
andANIM_animchannel_keyframes_loop
- all gpf_ok functions need to be implemented, so they match the type
. This consists more or less in re-writingED_gpencil_layer_select_frame
,ED_gpencil_layer_select_frames
,ED_gpencil_layer_frames_select_region
,ED_gpencil_layer_frames_select_box
but with different input parameters.
Would that be ok ?
FIY, so far, I’ve implemented option 2 because it was the easiest and just to make sure it worked, and it seems ok.
