gLTF batch export
We are working with a large number of objects and exporting each one of them as a gLTF (together with custom properties and draco compression) into directories named accordingly exactly the same as the objects itself. Is there any way we can automate this process? As exporting hundreds of them manually isn’t optimal. This is what we would like to achieve:
  1. Export only selected objects as a gLTF Separate (.gltf + .bin + textures) with compression and custom properties, and the file name model
  2. Define export path e.g. D:/assets/
  3. Export everything automatically into corresponding directories
D:/assets/Cone/
D:/assets/Cube/
D:/assets/Cylinder/
Any guidance would be highly appreciated.
You would need to code that batch export with a python script, should not be hard, here you have a starting point:
would it be possible to adjust this add-on to save objects per glTF file?
thank you in advance
# ##### BEGIN GPL LICENSE BLOCK #####
#  This program is free software; you can redistribute it and/or
#  modify it under the terms of the GNU General Public License
#  as published by the Free Software Foundation; either version 2
#  of the License, or (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with this program; if not, write to the Free Software Foundation,
#  Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# ##### END GPL LICENSE BLOCK #####
# <pep8 compliant>
bl_info = {
    "name": "Export multiple OBJ files",
    "author": "p2or, brockmann",
    "version": (0, 2, 0),
    "blender": (2, 80, 0),
    "location": "File > Import-Export",
    "description": "Export multiple OBJ files, UV's, materials",
    "warning": "",
    "wiki_url": "",
    "tracker_url": "",
    "category": "Import-Export"}
import bpy
import os
from bpy_extras.io_utils import ExportHelper
from bpy.props import (BoolProperty,
                       FloatProperty,
                       StringProperty,
                       EnumProperty,
                       CollectionProperty
class ExportMultipleObjs(bpy.types.Operator, ExportHelper):
    """Batch export objects as obj files"""
    bl_idname = "export_scene.batch_obj"
    bl_label = "Batch export OBJ's"
    bl_options = {'PRESET', 'UNDO'}
    # ExportHelper mixin class uses this
    filename_ext = ".obj"
    filter_glob = StringProperty(
            default="*.obj;*.mtl",
            options={'HIDDEN'},
    # List of operator properties, the attributes will be assigned
    # to the class instance from the operator setting before calling.
    # context group
    use_selection_setting: BoolProperty(
            name="Selection Only",
            description="Export selected objects only",
            default=True,
    use_animation_setting: BoolProperty(
            name="Animation",
            description="Write out an OBJ for each frame",
            default=False,
    # object group
    use_mesh_modifiers_setting: BoolProperty(
            name="Apply Modifiers",
            description="Apply modifiers (preview resolution)",
            default=True,
    # extra data group
    use_edges_setting: BoolProperty(
            name="Include Edges",
            description="",
            default=True,
    use_smooth_groups_setting: BoolProperty(
            name="Smooth Groups",
            description="Write sharp edges as smooth groups",
            default=False,
    use_smooth_groups_bitflags_setting: BoolProperty(
            name="Bitflag Smooth Groups",
            description="Same as 'Smooth Groups', but generate smooth groups IDs as bitflags "
                        "(produces at most 32 different smooth groups, usually much less)",
            default=False,
    use_normals_setting: BoolProperty(
            name="Write Normals",
            description="Export one normal per vertex and per face, to represent flat faces and sharp edges",
            default=False,
    use_uvs_setting: BoolProperty(
            name="Include UVs",
            description="Write out the active UV coordinates",
            default=True,
    use_materials_setting: BoolProperty(
            name="Write Materials",
            description="Write out the MTL file",
            default=True,
    use_triangles_setting: BoolProperty(
            name="Triangulate Faces",
            description="Convert all faces to triangles",
            default=False,
    use_nurbs_setting: BoolProperty(
            name="Write Nurbs",
            description="Write nurbs curves as OBJ nurbs rather than "
                        "converting to geometry",
            default=False,
    use_vertex_groups_setting: BoolProperty(
            name="Polygroups",
            description="",
            default=False,
    use_blen_objects_setting: BoolProperty(
            name="Objects as OBJ Objects",
            description="",
            default=True,
    group_by_object_setting: BoolProperty(
            name="Objects as OBJ Groups ",
            description="",
            default=False,
    group_by_material_setting: BoolProperty(
            name="Material Groups",
            description="",
            default=False,
    keep_vertex_order_setting: BoolProperty(
            name="Keep Vertex Order",
            description="",
            default=False,
    axis_forward_setting: EnumProperty(
            name="Forward",
            items=(('X', "X Forward", ""),
                   ('Y', "Y Forward", ""),
                   ('Z', "Z Forward", ""),
                   ('-X', "-X Forward", ""),
                   ('-Y', "-Y Forward", ""),
                   ('-Z', "-Z Forward", ""),
            default='-Z',
    axis_up_setting: EnumProperty(
            name="Up",
            items=(('X', "X Up", ""),
                   ('Y', "Y Up", ""),
                   ('Z', "Z Up", ""),
                   ('-X', "-X Up", ""),
                   ('-Y', "-Y Up", ""),
                   ('-Z', "-Z Up", ""),
            default='Y',
    global_scale_setting: FloatProperty(
            name="Scale",
            min=0.01, max=1000.0,
            default=1.0,
    def execute(self, context):
        # get the folder
        folder_path = os.path.dirname(self.filepath)
        # get objects selected in the viewport
        viewport_selection = context.selected_objects
        # get export objects
        obj_export_list = viewport_selection
        if self.use_selection_setting == False:
            obj_export_list = [i for i in context.scene.objects]
        # deselect all objects
        bpy.ops.object.select_all(action='DESELECT')
        for item in obj_export_list:
            item.select_set(True)
            if item.type == 'MESH':
                file_path = os.path.join(folder_path, "{}.obj".format(item.name))
                bpy.ops.export_scene.obj(
                        filepath=file_path,
                        use_selection=self.use_selection_setting,
                        axis_forward=self.axis_forward_setting,
                        axis_up=self.axis_up_setting,
                        use_animation=self.use_animation_setting,
                        use_mesh_modifiers=self.use_mesh_modifiers_setting,
                        use_edges=self.use_edges_setting,
                        use_smooth_groups=self.use_smooth_groups_setting,
                        use_smooth_groups_bitflags=self.use_smooth_groups_bitflags_setting,
                        use_normals=self.use_normals_setting,
                        use_uvs=self.use_uvs_setting,
                        use_materials=self.use_materials_setting,
                        use_triangles=self.use_triangles_setting,
                        use_nurbs=self.use_nurbs_setting,
                        use_vertex_groups=self.use_vertex_groups_setting,
                        use_blen_objects=self.use_blen_objects_setting,
                        group_by_object=self.group_by_object_setting,
                        group_by_material=self.group_by_material_setting,
                        keep_vertex_order=self.keep_vertex_order_setting,
                        global_scale=self.global_scale_setting
            item.select_set(False)
        # restore viewport selection
        for ob in viewport_selection:
            ob.select_set(True)
        return {'FINISHED'}
# Only needed if you want to add into a dynamic menu
def menu_func_import(self, context):
    self.layout.operator(ExportMultipleObjs.bl_idname, text="Wavefront Batch (.obj)")
def register():
    bpy.utils.register_class(ExportMultipleObjs)
    bpy.types.TOPBAR_MT_file_export.append(menu_func_import)
def unregister():
    bpy.utils.unregister_class(ExportMultipleObjs)
    bpy.types.TOPBAR_MT_file_export.remove(menu_func_import)
if __name__ == "__main__":
    register()
    # test call
    #bpy.ops.export_scene.multiple_objs('INVOKE_DEFAULT')
The meat of the script is this:
import bpy
import os
def export_selected_objects(path):
    # path fixing (many other validations to be added here)
    path = os.path.abspath(path)
    # get list of selected objects
    selected_list = bpy.context.selected_objects
    # deselect all in scene
    bpy.ops.object.select_all(action='TOGGLE')
    # loop all initial selected objects
    for o in selected_list:
        # select the object
        bpy.context.scene.objects[o.name].select_set(True)
        # create directory
        outpath = os.path.join(path, o.name)
        os.mkdir(outpath)
        # set filename
        outpath = os.path.join(outpath, o.name+'.glb')
        # export it
        # many other parameters can be added here
        bpy.ops.export_scene.gltf(
            filepath=outpath,
            #export_selected=True (I got a warning here)
            use_selection=True
        # deselect
        bpy.context.scene.objects['Cube'].select_set(True)
export_selected_objects('D:\\')
Many other tasks are left, since I can’t test all of the parameters myself, for texturing and compression and validate them.
Other secondary tasks:
  • Wrap things up into an addon for ease of use.
