Get ui element under mouse
Hi, is there a function which returns the ui area/element/property the mouse is currently over?
Properties (ie: BoolProperty, FloatProperty, etc) have no event callbacks such as “onmouseover”, only update or get/set callbacks.
Operators (ie: buttons) can have their properties assigned during invoke op = layout.operator(...) however this means that the values are set during the panel layout.
What are you trying to implement? There might be a workaround.
I think I might be getting somewhere near a resolution:
Here’s what I have so far, but I think I might be barking up the wrong tree.
import bpy
from bl_ui.space_toolsystem_toolbar import  ToolDef
from bl_ui.space_toolsystem_common import description_from_id, ToolSelectPanelHelper
class NOTE_OT_printtooldef(bpy.types.Operator):
    bl_idname = "note.printtooldef"
    bl_label = "print the tool description"
    def execute(self, context):
        space_type = context.space_data.type
        tool = ToolSelectPanelHelper.tool_active_from_context(context)
        description = **HOW TO GET DESCRIPTION**
        print(description)
        return {'FINISHED'}
