Get the sound intensity of a current frame
Hey
I’d like to know what is the sound intensity of a frame (if there’s sound object in the scene or audio playing in the sequencer) via bpy to create a little python “audio volume” input node for geometry node.
AFAIK there’s no api for this ? I hope I am wrong
There is no direct way, but in this add-on is a way to do a VU-meter: https://github.com/snuq/VSEQF
thanks a lot @tintwotin
to anyone interested here is the function without dependencies to the rest of this fantastic plugin below :slight_smile: (except for fades)
could we perhaps have some information about what the unit represents?
the sequencer starts to draw the sound red when it hit a certain limit, so suppose i can use this to normalize, not sure what this limit is at the first place
Cheers
def get_sequence_volume(frame=None):
    """source: https://github.com/snuq/VSEQF/blob/3ac717e1fa8c7371ec40503428bc2d0d004f0b35/vseqf.py#L142"""
    total = 0
    if bpy.context.scene.sequence_editor is None:
        return 0
    sequences = bpy.context.scene.sequence_editor.sequences_all
    depsgraph = bpy.context.evaluated_depsgraph_get()
    if frame is None:
          frame = bpy.context.scene.frame_current
          evaluate_volume = False
    else: evaluate_volume = True
    fps = bpy.context.scene.render.fps / bpy.context.scene.render.fps_base
    for sequence in sequences:
        if (sequence.type=="SOUND" and sequence.frame_final_start<frame and sequence.frame_final_end>frame and not sequence.mute):
            time_from = (frame - 1 - sequence.frame_start) / fps
            time_to = (frame - sequence.frame_start) / fps
            audio = sequence.sound.evaluated_get(depsgraph).factory
            chunk = audio.limit(time_from, time_to).data()
            #sometimes the chunks cannot be read properly, try to read 2 frames instead
            if (len(chunk)==0):
                time_from_temp = (frame - 2 - sequence.frame_start) / fps
                chunk = audio.limit(time_from_temp, time_to).data()
            #chunk still couldnt be read... just give up :\
            if (len(chunk)==0):
                average = 0
            else:
                cmax = abs(chunk.max())
                cmin = abs(chunk.min())
                if cmax > cmin:
                      average = cmax
                else: average = cmin
            if evaluate_volume:
                fcurve = fades.get_fade_curve(bpy.context, sequence, create=False)
                if fcurve:
                      volume = fcurve.evaluate(frame)
                else: volume = sequence.volume
            else:
            total = total + (average * volume)
        continue
    return total
volume = get_sequence_volume()
print(volume)
Question is if this could be a built in operator so it could be used for a VU-meter and be exposed in the API?
