scale element might also work but in my case this setup doesn’t work
I m trying to create a procedural bevel after boolean and because I m extruding a curve generated from the intersection between 2 object the curve change direction every time I move one of the objects so I m try to fix this by flipping the polygons. Here is the scene…
