Geometry Nodes
Hi Astronet,
I believe this can be achieved if you use the “ID” node and plug it into the “Attribute Capture” node, switch to the “Spline” domain so that you can set the IDs for each individual spline. In any further cases where you want to set and store values on different domains, I’d highly recommend checking the “Attribute Capture” node, it basically allows you to store values in desired domains.
