Geometry Nodes
EDIT: I turned out being wrong, see Geometry Nodes - #1978 by HooglyBoogly
Well, try it youself, have your GN on the default cube, and connect a curve primitive to the output, select the object and see the colors of the outlines:
Curves will always be instances if the object itself is a mesh.
