Newest build from yesterday. Win 7, VS 2017
In the last week the internal naming of the editors has changed in the code. tbuts is now space_buttons for example.
I have my own default theme in my custom build. And so i have run the blender_theme_as_c.py file against a saved userpref.blend to update it to the new names. The created userdef_default_theme.c file uses still the old names though. And so compilation fails with all the old editor names, tbuts, tv3d, tfile, tipo, and so on.
I can of course manually rename the classes in the file, and i have. But there is a hint above not to hand edit the file. And i have yet to find out why the string upleft in the 3D view turned grey here.
Is there a newer version of the blender_theme_as_c.py conversion file around? Do i something wrong here? Or is this a overlooked issue, and this part isn’t covered by the renaming of the spaces yet?
Every help and hint is welcome
Kind regards
Arunderan
