Hello, you are trying to render with POV-Ray… and you haven’t installed it yet on your machine. So you can do one of (at least) two things: just chose another renderer from the rolldown, or install it and it should be autodetected from registry keys. If it is not, the addon preferences have a field where you can manually specify the pvengine64.exe binary path.
You wrong. He says he is trying to install the addon. Not trying to use it.
File “J:\Software\Blender\blender-2.92.0-windows64\2.92\scripts\modules\addon_utils.py”, line 351, in enable
mod = import(module_name)
File “C:\Users\wille\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\BYASP-master_init_.py”, line 26, in
from . import bface
File “C:\Users\wille\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\BYASP-master\bface.py”, line 17, in
from . import facs_process as facs
File “C:\Users\wille\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\BYASP-master\facs_process.py”, line 4, in
from scipy.signal import savgol_filter
ModuleNotFoundError: No module named ‘scipy’
I get this when trying to installl an addon. Its for blender 2.91, Does this mean the addon needs to be updated
