Hi!
I’m new to this, not familiar with the blender codebase, but hoping I can get some help here. This issue has been plaguing me and a ton of my peers forever now, and it really needs to get solved, so I’m finally taking it into my own hands. It’s how cycles handles the phase functions of volume scattering when there are overlapping volumes, example:
The cube with the dense volume and high anisotropy completely glitches out as the phase function of the light gets set to match the phase function of the less dense volume.
I’ve successfully compiled blender, I’ve isolated the section of code which I believe to be the issue, here it is:
(volume_shader.h in the cycles kernel integrator)
Someone already commented a reference to this issue at the bottom (I believe). This is not an uncommon issue despite what the comment says, the most common usage for volumetrics is for atmospheres, and if you place a volumetric object in your scene, be it a cloud, explosion, dust, etc. it starts behaving unpredictably.
I’m eager to tackle this myself if necessary, but this is also a cry for help because I honestly do not know my way around c++. It seems to be a simple fix, but still a bit daunting. I hope to at least get some eyes towards this. fixing this is integral to many peoples’ workflows. Right now we can’t even put volumetric clouds in the sky without issue.
