Hi all,
I am the head of physics research at nvidia and for prototyping I have used the obj file format a lot because it is so simple. One big drawback is that it cannot store skeletal animation info. For that you have to use FBX for instance. I wrote code to read that in the past but you have to import the FBX library and it is quite cumbersome to use it.
Now I have a suggestion to extend OBJ in a very simple way to support animation info. I have written a Blender exporter and an example to read it back in already.
Here is my suggestion. I wonder whether it would make sense to add that to the official OBJ exporter of Blender. The extension looks like this:
Definition of the skeleton
b [bone name]
bp [parent bone nr + 1, 0 = no parent]
bb [16 floats for 4x4 bind pose]
Skinning info
vl [vertex number + 1] [bone number] [weight] [bone number] [weight] …
Animations
a [name]
af rot.x rot.y rot.z rot.w [pos.x pos.y pos.z] [scale.x scale.y scale.z]
af defines a transformation per bone per frame so there are num bones x num frames such entries. Since those are most often just rotations (quaternions) the pos and scale info can be ombitted to reduce file size
What do you guys think?
Here is an actual example:
b root
bp 0
bb 0.062615 0.000199 -0.147239 -0.000562 0.000591 0.159998 0.000467 0.700159 0.147238 -0.000727 0.062613 -0.007725 0.000000 0.000000 0.000000 1.000000
b clavicle
bp 1
bb 0.007516 -0.158770 -0.018321 -0.000049 0.159789 0.007846 -0.002440 1.113234 0.003319 -0.018182 0.158929 -0.009602 0.000000 0.000000 0.000000 1.000000
b humerus
bp 2
bb 0.013231 -0.159246 -0.008105 -0.213310 0.000666 -0.008078 0.159795 1.123772 -0.159451 -0.013248 -0.000005 -0.034025 0.000000 0.000000 0.000000 1.000000
b radius
bp 3
bb -0.015432 -0.159234 0.002522 -0.492860 0.000245 0.002510 0.159980 1.109591 -0.159254 0.015434 0.000002 -0.057281 0.000000 0.000000 0.000000 1.000000
vl 3582 2 0.048444 1 0.951556
vl 3583 2 0.055316 1 0.944684
vl 3584 2 0.048894 1 0.951106
vl 3585 2 0.040274 1 0.959726
a armMotion
110 frames
frame 1
af 0.000000 0.000000 0.000000 1.000000
frame 2
af 0.000001 0.016234 0.000258 0.992926
frame 3
