My goal is to export multiple objects via the bpy.ops.export_scene.gltf function inside a for loop.
It is important to note that each object has its own children.
Problem:
Although it exports 3 different files (with different names), it only takes the latest object from the list.
Let’s say, for example…
I am selecting - obj 1, obj 2, obj 3 → It will create 3 different files with 3 different names, but the content of each file is the same = last object (obj 3).
Any help will be appreciated !
Code:
import bpy
import copy
print("********** BLENDER TO WEBGL EXPORTER **********\n")
# Set export directory
directory = "C:/Models/...."
# Make a list of selected objects
selection = [obj for obj in bpy.context.selected_objects]
print("\nSelected Models List:", selection)
bpy.ops.object.select_all(action='DESELECT') #deselect all
def exportModel(parentModel):
print('Exporting Parent: ', parentModel)
# Select all visible objects grouped
bpy.ops.object.select_grouped(type='CHILDREN_RECURSIVE')
# Select parentModel and make it active
parentModel.select_set(True)
# Export to GLB/GLTF
bpy.ops.export_scene.gltf(filepath= directory + parentModel.name + ".glb", export_format="GLB",use_selection = True, )
def loopOverModels():
# for obj in se
for parentIndex in range(len(selection)): # 3
# Select current obj
bpy.data.objects[selection[parentIndex].name].select_set(True)
print("\n=== Object Name:" + selection[parentIndex].name)
print("\n===Object Index:" + str (parentIndex))
print ("\n===Object Children:" , selection[parentIndex].children)
# Get object position
originalPosition = copy.copy(selection[parentIndex].location)
# Set object location to new position = center.
selection[parentIndex].location = (0,0,0)
print("\n ********** EXPORTING ********** \n")
exportModel(selection[parentIndex])
# Set object position to it's original one.
selection[parentIndex].location = originalPosition
# Deselect the object
print(selection[parentIndex].name + " - DONE\n====================================" )
