Everything is blurry in the viewport and when it’s rendering
Support
Compositing and Post Processing
modeling texturing architecture render
Do you want live notifications when people reply to your posts? Enable Notifications
botaniq_6.1_BlenderArtists_banner_HEX_3
Support
DenaT
12m
I rendered the scene. I used Denoising to remove noise. Everything was rendered clearly, then something happened. Now everything is blurry in the viewport and when it’s rendering.
This is result https://yadi.sk/i/ufifWoa0CjK_Jw
I know that this is in viewport, but it also don’t work in render.
I reset the settings to the factory settings, and then even deleted the folder with user information - nothing helped. Everything is blurry.
What i should do?
P.s changing the number of samples, nothing changes
Previously, it worked and did not blur the picture - it just removed the noise. And now he blurs. Without Denoising, everything is in noise. Added Denoising in the compositing tab, the situation is the same. Everything blurs, instead of removing the noise
https://yadi.sk/i/h9ykebOWOY671Q I made this render before with Denoising
This forum is about Blender development. For help using Blender, please try one of the user websites:
If you think you found a bug, please use the bug report form:
https://developer.blender.org/maniphest/task/edit/form/1/
