Errors building Master
Hi, get errors building Master fbd9c09ef0cb91a1c19a1a43cbc69856efc6d989 from today, work Yesterday.
[100%] Linking CXX executable …/…/bin/blender
/usr/lib64/gcc/x86_64-suse-linux/9/…/…/…/…/x86_64-suse-linux/bin/ld: …/…/lib/libcycles_device.a(device_cpu.cpp.o):
in function ccl::CPUDevice::CPUDevice(ccl::DeviceInfo&, ccl::Stats&, ccl::Profiler&, bool)': device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInf oERNS_5StatsERNS_8ProfilerEb]+0x1f3): undefined reference to ccl::kernel_cpu_sse41_path_trace(ccl::KernelGlobals*, float
, int, int, int, int, int)’
/usr/lib64/gcc/x86_64-suse-linux/9/…/…/…/…/x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x212): undefined
reference to ccl::kernel_cpu_avx2_convert_to_half_float(ccl::KernelGlobals*, ccl::uchar4*, float*, float, int, int, int, int)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x219): undefined reference to ccl::kernel_cpu_avx_convert_to_half_float(ccl::KernelGlobals
int)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x220): undefined
reference to ccl::kernel_cpu_sse41_convert_to_half_float(ccl::KernelGlobals*, ccl::uchar4*, float*, float, int, int, int , int)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x249): undefined reference to ccl::kernel_cpu_avx2_convert_to_byte(ccl::KernelGlobals*, ccl::uchar4*, float*, float, int, int, int, int)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x257): undefined
reference to ccl::kernel_cpu_avx_convert_to_byte(ccl::KernelGlobals*, ccl::uchar4*, float*, float, int, int, int, int)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x25e): undefined reference to ccl::kernel_cpu_sse41_convert_to_byte(ccl::KernelGlobals*, ccl::uchar4*, float*, float, int, int, int, int)
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x303): undefined
reference to ccl::kernel_cpu_sse41_shader(ccl::KernelGlobals*, ccl::uint4*, ccl::float4*, int, int, int, int, int)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x9c3): undefined reference to ccl::kernel_cpu_data_init(ccl::KernelGlobals*, ccl::KernelData const*, void*, int, char*, int, int, int, in
t, int, int, int, int, int*, int, char*, unsigned int*, unsigned int, float*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xb7d): undefined
reference to ccl::kernel_cpu_sse3_path_init(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xba3): undefined reference to ccl::kernel_cpu_path_init(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xc16): undefined
reference to ccl::kernel_cpu_sse3_scene_intersect(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xc24): undefined reference to ccl::kernel_cpu_scene_intersect(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xc9f): undefined
reference to ccl::kernel_cpu_sse3_lamp_emission(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xcad): undefined reference to ccl::kernel_cpu_lamp_emission(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xd21): undefined
reference to ccl::kernel_cpu_sse3_do_volume(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xd2f): undefined reference to ccl::kernel_cpu_do_volume(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xd9c): undefined
reference to ccl::kernel_cpu_sse3_queue_enqueue(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xdaa): undefined reference to ccl::kernel_cpu_queue_enqueue(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xe21): undefined
reference to ccl::kernel_cpu_sse3_indirect_background(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xe2f): undefined reference to ccl::kernel_cpu_indirect_background(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xec5): undefined
reference to ccl::kernel_cpu_sse3_shader_setup(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xed3): undefined reference to ccl::kernel_cpu_shader_setup(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xf42): undefined
reference to ccl::kernel_cpu_sse3_shader_sort(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xf50): undefined reference to ccl::kernel_cpu_shader_sort(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xfc8): undefined
reference to ccl::kernel_cpu_sse3_shader_eval(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0xfd6): undefined reference to ccl::kernel_cpu_shader_eval(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x104a): undefined
reference to ccl::kernel_cpu_sse3_holdout_emission_blurring_pathtermination_ao(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1058): undefined reference to ccl::kernel_cpu_holdout_emission_blurring_pathtermination_ao(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1102): undefined
reference to ccl::kernel_cpu_sse3_subsurface_scatter(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1110): undefined reference to ccl::kernel_cpu_subsurface_scatter(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x11a5): undefined
reference to ccl::kernel_cpu_sse3_direct_lighting(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x11b3): undefined reference to ccl::kernel_cpu_direct_lighting(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1231): undefined
reference to ccl::kernel_cpu_sse3_shadow_blocked_ao(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x123f): undefined reference to ccl::kernel_cpu_shadow_blocked_ao(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x12cc): undefined
reference to ccl::kernel_cpu_sse3_shadow_blocked_dl(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x12da): undefined reference to ccl::kernel_cpu_shadow_blocked_dl(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1367): undefined
reference to ccl::kernel_cpu_sse3_enqueue_inactive(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1375): undefined reference to ccl::kernel_cpu_enqueue_inactive(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1400): undefined
reference to ccl::kernel_cpu_sse3_next_iteration_setup(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x140e): undefined reference to ccl::kernel_cpu_next_iteration_setup(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x14a0): undefined
reference to ccl::kernel_cpu_sse3_indirect_subsurface(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x14ae): undefined reference to ccl::kernel_cpu_indirect_subsurface(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1544): undefined
reference to ccl::kernel_cpu_sse3_buffer_update(ccl::KernelGlobals*, ccl::KernelData*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x1552): undefined reference to ccl::kernel_cpu_buffer_update(ccl::KernelGlobals*, ccl::KernelData*)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x202d): undefined
reference to ccl::kernel_cpu_sse3_data_init(ccl::KernelGlobals*, ccl::KernelData const*, void*, int, char*, int, int, i nt, int, int, int, int, int, int*, int, char*, unsigned int*, unsigned int, float*)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x2326): undefined reference to ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x236e): undefined
reference to ccl::kernel_cpu_avx2_shader(ccl::KernelGlobals*, ccl::uint4*, ccl::float4*, int, int, int, int, int)' /usr/lib64/gcc/x86_64-suse-linux/9/../../../../x86_64-suse-linux/bin/ld: device_cpu.cpp:(.text._ZN3ccl9CPUDeviceC2ERNS_10 DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x2863): undefined reference to ccl::kernel_cpu_avx_shader(ccl::KernelGlobals*, ccl::uint4*, ccl::float4*, int, int, int, int, int)’
DeviceInfoERNS_5StatsERNS_8ProfilerEb[_ZN3ccl9CPUDeviceC5ERNS_10DeviceInfoERNS_5StatsERNS_8ProfilerEb]+0x2883): undefined
reference to `ccl::kernel_cpu_avx_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int)’
collect2: error: ld returned 1 exit status
make[2]: *** [source/creator/CMakeFiles/blender.dir/build.make:399: bin/blender] Fehler 1
make[1]: *** [CMakeFiles/Makefile2:7030: source/creator/CMakeFiles/blender.dir/all] Fehler 2
make: *** [Makefile:163: all] Fehler 2
I use GCC 9.1.1 on Opensuse Tumbleweed 64.
Thanks for watching, mib
Disable Embree in cmake fix the build error, no idea why.
Not to important for me anyway.
Mib
