I’m following the official guide for building blender on Windows (Windows - Blender Developer Documentation). I’ve already downloaded the source code, but am having trouble downloading the required Blender libraries.
I’ve tried to do this multiple times, and every time I do it I get this error:
Here is the input and output from the command terminal:
E:\blender-git>cd blender
E:\blender-git\blender>make update
No explicit msvc version requested, autodetecting version.
** Visual Studio 2022 Developer Command Prompt v17.12.0
** Copyright (c) 2022 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
Compiler Detection successful, detected VS2022
The required external libraries in lib/windows_x64 are missing
Would you like to download them? (y/n)y
Downloading lib/windows_x64 libraries, please wait.
* Note: Once the initial download finishes and you see *
* "Resolving deltas: 100% (nnn/nnn) done" *
* a second, much larger, update will occur with *
* no visible updates. Please do not interrupt *
* this process. It may take over an hour to *
* complete depending on your internet connection. *
Submodule 'lib/windows_x64' (https://projects.blender.org/blender/lib-windows_x64.git) registered for path 'lib/windows_x64'
Cloning into 'E:/blender-git/blender/lib/windows_x64'...
remote: Enumerating objects: 45973, done.
remote: Counting objects: 100% (45973/45973), done.
remote: Compressing objects: 100% (26424/26424), done.
remote: Total 45973 (delta 19015), reused 45533 (delta 18786), pack-reused 0
Receiving objects: 100% (45973/45973), 174.41 MiB | 1.07 MiB/s, done.
Resolving deltas: 100% (19015/19015), done.
Submodule path 'lib/windows_x64': checked out '283d5458d373814824e5675d6fcd7a67d7c50cfb'
Not in a Git repository.
Error during download, retry? y/n
This is my 3rd day of trying to build Blender - it’s been such a headache, any help would be greatly appreciated.
System specs:
OS: Windows 11 Home
Processor: Intel I7-10750H
Graphics Card: NVIDIA GeForce GTX 1660 Ti
Like i mentioned in the last topic unless i need a complete log of everything that has happened to your checkout, just the tail-end where you have issues won’t cut it.
Where would this log be located?
there is none, it’s just everything you typed and the results from that from the moment (and including) you ran git clone ....
I installed all the development tools (git, cmake, and reinstalled the Desktop Development with C++ workload, and updated VS 2022 for good measure)
Opened the command line (cmd . exe) with the windows key + r
Changed the cd to my external drive (cd /d E:/)
Changed the cd to E:blender-git
Once it finished installing the source code, I changed the cd to E:/blender-git/blender, and then ran
make update
hate to sound like a broken record, but unless you provide the actual text that was on your screen offering any help is extremely difficult.
Not sure it makes a difference, but what happens when you just type E:
instead of cd /d E:/
I think that it does the exact same thing.
I just reinstalled it. The download process was the exact same as the last time I did it:
C:\Users\tripp>E:
E:\>cd blender-git
E:\blender-git>git clone https://projects.blender.org/blender/blender.git
Cloning into 'blender'...
remote: Enumerating objects: 337568, done.
remote: Counting objects: 100% (337568/337568), done.
remote: Compressing objects: 100% (38981/38981), done.
remote: Total 1889923 (delta 329576), reused 299064 (delta 298586), pack-reused 1552355
Receiving objects: 100% (1889923/1889923), 768.07 MiB | 1005.00 KiB/s, done.
Resolving deltas: 100% (1643217/1643217), done.
Updating files: 100% (13815/13815), done.
E:\blender-git>
I ran make update again, after reinstalling the source code, Git, and CMake, but I still ran into the exact same error:
Microsoft Windows [Version 10.0.22631.4460]
(c) Microsoft Corporation. All rights reserved.
C:\Users\tripp>E:
E:\>cd blender-git\blender
Receiving objects: 100% (45973/45973), 174.41 MiB | 9.02 MiB/s, done.
Error during download, retry? y/ny
Error during download, retry? y/n^CTerminate batch job (Y/N)?
I ran make update
again, and now I’m getting an error saying that my version of Python is incompatible with the verison of Windows that I’m running. It’s worth noting that I also tried the git lfs pull
+ git lfs checkout main
as per LazyDodo’s instructions, which worked for somone else that had the same issue, but not for me.
C:\Users\tripp>cd E:
E:\
C:\Users\tripp>E:
This version of E:\blender-git\blender\lib\windows_x64\python\311\bin\python.exe is not compatible with the version of Windows you're running. Check your computer's system information and then contact the software publisher.
E:\blender-git\blender>cd lib\windows_x64
E:\blender-git\blender\lib\windows_x64>git lfs pull
E:\blender-git\blender\lib\windows_x64>git lfs checkout main
E:\blender-git\blender\lib\windows_x64>cd ..\..\
E:\blender-git\blender>cd E:\blender-git\blender\lib\windows_x64\p
The system cannot find the path specified.
E:\blender-git\blender>cd \blender-git\blender\lib\windows_x64
E:\blender-git\blender\lib\windows_x64>lfs checkout main
'lfs' is not recognized as an internal or external command,
operable program or batch file.
