Thanks for all developers working on the Geometry Nodes. I just started tinkering with the codes of Geometry Nodes. I found some issues with the Elapsed Time socket of the Simulation Input Node. I apologize if this is not the forum to post issues found in the latest build. Please let me know the appropriate place to post.
The following Geometry Node tree is attached to the default cube. I expect it to have motions in both x- and y-axis. But it only moves along x-axis. I changed the speed in the Multiply node, but it has no effect. The Elapsed time seems to be always zero.
The Blender file is here: Easyupload.io - Upload files for free and transfer big files easily. Tested on the build based on latest code as of Dec 6, 2022.
