Hi
I was wondering if it’s possible to dynamically draw subpanels based on the settings in the parent panel?
Look at the MeasureIt add-on included in Blender, menu panels change dynamically based upon what you are doing, this should give you some pointers.
You can also put conditional statements in the draw() method like:
If variable == 'Set'"
col.prop(etc.......
else:
Do something else...
You need a method to update the sub-panel, look in MeasureIt for how this is done.
Cheers, Clock.
Here’s a code snippet from MeasureIt Init file:
# Register all operators and panels
# Add-ons Preferences Update Panel
# Define Panel classes for updating
panels = (
measureit_main.MEASUREIT_PT_Edit,
measureit_main.MEASUREIT_PT_Main,
measureit_main.MEASUREIT_PT_Conf,
measureit_main.MEASUREIT_PT_Render,
def update_panel(self, context):
message = "MeasureIt: Updating Panel locations has failed"
try:
for panel in panels:
if "bl_rna" in panel.__dict__:
bpy.utils.unregister_class(panel)
panel.bl_category = context.preferences.addons[__name__].preferences.category
bpy.utils.register_class(panel)
except Exception as e:
print("\n[{}]\n{}\n\nError:\n{}".format(__name__, message, e))
pass
