Is there a “sanctioned” docker image to build the blender official release on linux these days?
Context:
We are struggling to find the proper tool chain, i.e. combination of distro / gcc / nvcc, that will use the latest prebuilt deps and builds the CUDA kernels.
Our latest attempt:
“make release” yields very quickly:
In file included from /usr/local/cuda/bin/…/targets/x86_64-linux/include/cuda_runtime.h:83,
/usr/local/cuda/bin/…/targets/x86_64-linux/include/crt/host_config.h:138:2:
error: #error – unsupported GNU version! gcc versions later than 8 are not supported!
Thank you!
Olivier
PS: We are also interested in the recommended solution to this particular gcc 9.3 / nvcc 10.2 mismatch.
afaik there is no docker, but try turning on WITH_CYCLES_CUBIN_COMPILER in cmake
Thanks LazyDodo, it seems to work so far
FYI, I just created this Dockerfile in order to compile on Ubuntu 20.04 (used so far only for make lite ninja).
# HOW TO BUILD THE DOCKER IMAGE:
# `docker build -t blenduntu ./`
# HOW TO COMPILE BLENDER:
# - On the host, follow instruction to clone blender-git repo and install precompiled library (see https://wiki.blender.org/wiki/Building_Blender/Linux/Ubuntu)
# - Run the container which will start a prompt (which binds the blender-git folder to the container):
# `docker run -ti --rm --mount type=bind,source=<path-to-blender-git-on-host>,target=/home/blender/blendet-git blenduntu`
# - From the container prompt:
# `cd blender-git/blender`
# `make ccache ninja`
# NOTES: this image is not meant to manage git update / make update of the repo which should be done on the host OS.
FROM ubuntu:20.04 AS blenduntu
USER root
ENV LANG en_US.utf8
RUN apt-get update && \
apt-get install -y locales software-properties-common && \
localedef -i en_US -c -f UTF-8 -A /usr/share/locale/locale.alias en_US.UTF-8 && \
ln -fs /usr/share/zoneinfo/Europe/Paris /etc/localtime && \
DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends tzdata && \
add-apt-repository -y ppa:ubuntu-toolchain-r/test && \
apt-get update && \
apt-get install -y build-essential git subversion cmake libx11-dev libxxf86vm-dev \
libxcursor-dev libxi-dev libxrandr-dev libxinerama-dev libegl-dev \
libwayland-dev wayland-protocols libxkbcommon-dev libdbus-1-dev \
linux-libc-dev gcc-11 g++-11 ninja-build ccache && \
rm -rf /var/lib/apt/lists/* && \
useradd -ms /bin/bash blender
USER blender
WORKDIR /home/blender
ENV BUILD_CMAKE_ARGS="-DCMAKE_CXX_COMPILER=g++-11 -DCMAKE_C_COMPILER=gcc-11"
