Hi guys,
I am trying to determine the RNA path for a node property. Using bpy.ops.ui.copy_data_path_button() does not work with PropertyGroup for some reason… Instead, I was trying to identify the UI element under mouse in order to determine it’s type and calculate the path. I was able so far to identify the node under mouse using the code from nodewrangler, but not the UI elements inside the node. Any ideas?
Related issues “closed” without a solution:
https://developer.blender.org/T51096
https://developer.blender.org/T69803
https://developer.blender.org/T69973
Probable cause: "The Python tooltips are incomplete for PropertyGroups
because RNA_path_full_property_py_ex()
( rna_access.c
) doesn’t return a full path.” https://blender.stackexchange.com/questions/158408/turning-off-anti-aliasing-inconsistency-between-info-window-and-valid-python
