Hi there,
I am having problems with an add-on operator that creates an object, parent it to a camera, and then sets drivers on that object transforms, driven by some camera settings.
The issue is that after running that operator, if I delete the camera or the object, Blender crashes.
However, if I save the scene, close and reopen it, then it works fine. It crashes only after running the operator, so it’s hard for me to create a bug report because I can’t provide a scene to reproduce it.
It’s really the drivers that are the cause of the crash, everything is stable if I comment out the drivers code. I tried to not parent the object, or use an intermediary empty or constraints instead of parenting, but it’s still crashes.
I can’t share the entire add-on because it’s not free, so I recreated that operator inside Blender Scripting, for devs to be able to reproduce the crash. And of course, it doesn’t crash… I wonder if it registers differently from an external add-on.
I attached that blend file here, so you can see the script.
I’d like to know if someone knows of a workaround, or can decrypt the crash report and give me some clues about what could be the cause.
blender.crash.txt (46.6 KB)
ExceptionCode : EXCEPTION_ACCESS_VIOLATION
Exception Address : 0x00007FF7ABD40534
Exception Module : blender.exe
Exception Flags : 0x00000000
Exception Parameters : 0x2
Parameters[0] : 0x0000000000000000
Parameters[1] : 0x0000000000000060
Stack trace:
blender.exe :0x00007FF7ABD402B0 library_foreach_ID_link
blender.exe :0x00007FF7ABD3FBE0 BKE_library_foreach_ID_link
blender.exe :0x00007FF7ABD27D20 BKE_id_copy_ex
blender.exe :0x00007FF7AC6447E0 blender::deg::deg_expand_copy_on_write_datablock
blender.exe :0x00007FF7AC644CE0 blender::deg::deg_update_copy_on_write_datablock
blender.exe :0x00007FF7AC644780 blender::deg::deg_evaluate_copy_on_write
blender.exe :0x00007FF7AC6602B0 blender::deg::`anonymous namespace'::evaluate_node
blender.exe :0x00007FF7AC660260 blender::deg::`anonymous namespace'::deg_task_run_func
tbb.dll :0x00007FF9231A51D0 tbb::interface7::internal::isolate_within_arena
blender.exe :0x00007FF7AFA80550 tbb::internal::function_task<Task>::execute
tbb.dll :0x00007FF9231B37A0 tbb::recursive_mutex::scoped_lock::internal_try_acquire
tbb.dll :0x00007FF9231AA490 tbb::task_scheduler_init::terminate
tbb.dll :0x00007FF9231B19C0 tbb::thread_bound_filter::try_process_item
ucrtbase.dll :0x00007FF9D7890F70 beginthreadex
KERNEL32.DLL :0x00007FF9D9BF7C10 BaseThreadInitThunk
ntdll.dll :0x00007FF9D9D4D4B0 RtlUserThreadStart
Threads:
Thread : 000024f8
ntdll.dll :0x00007FF9D9D7CFA0 ZwYieldExecution
KERNELBASE.dll :0x00007FF9D6E6CF70 SwitchToThread
blender.exe :0x00007FF7AC90D010 tbb::internal::task_group_base::wait
blender.exe :0x00007FF7AC65FDF0 blender::deg::deg_evaluate_on_refresh
blender.exe :0x00007FF7AC63AE60 DEG_evaluate_on_refresh
blender.exe :0x00007FF7ABD2FBA0 scene_graph_update_tagged
blender.exe :0x00007FF7AC0E8C80 rna_ViewLayer_update_tagged
blender.exe :0x00007FF7AC0D4210 RNA_function_call
blender.exe :0x00007FF7AC1D08E0 pyrna_func_call
python37.dll :0x00007FF9229462F0 PyObject_FastCallKeywords
python37.dll :0x00007FF922A13FA0 PyEval_GetFuncDesc
python37.dll :0x00007FF922A0E490 PyEval_EvalFrameDefault
python37.dll :0x00007FF9229464E0 PyObject_Call
python37.dll :0x00007FF9229469C0 PyFunction_FastCallKeywords
python37.dll :0x00007FF922A12550 PyEval_EvalCodeWithName
python37.dll :0x00007FF922946740 PyFunction_FastCallDict
python37.dll :0x00007FF922947730 PyObject_Call_Prepend
python37.dll :0x00007FF9229A6D00 PyType_Ready
blender.exe :0x00007FF7AC1D3CF0 bpy_class_call
blender.exe :0x00007FF7AC0EECD0 rna_operator_modal_cb
blender.exe :0x00007FF7ABED8A20 wm_handler_operator_call
blender.exe :0x00007FF7ABED99B0 wm_handlers_do_intern
blender.exe :0x00007FF7ABED9000 wm_handlers_do
blender.exe :0x00007FF7ABED6520 wm_event_do_handlers
blender.exe :0x00007FF7ABEC1FF0 WM_main
blender.exe :0x00007FF7ABC41AE0 main
blender.exe :0x00007FF7AFF91398 __scrt_common_main_seh
