I’ve set up Python debugging in Blender on Windows as describe here and it works, partially:
I can set a breakpoint from within the source using pydevd.settrace(), but any breakpoints I set in Eclipse are ignored. As soon as I click resume, it runs until the end of the script or until the next pydevd.settrace().
I have analyzed the debugger communication with wireshark and found that when starting the script with “run script” from the internal text editor, the wrong path is transmitted, e.g. “C:\users\test\desktop\test.blend\scriptname.py” if the blendfile is named “test.blend”.
If I start the script using “execfile(“C:\users\test\desktop\scriptname.py”)” the correct path is sent to eclipse and breakpoints work fine.
Is there a better way to debug python with Eclipse?
If not, how can I correct the Wiki entry?
