Thanks for that work!
I could build the code on WIndows by building the project files manually. The cmake procedure asks for too much input for my use. I don’t need the GUI.
I only had one issue with the now double files half.h, one from util and one from OpenimageIO. The include sequence seems to be unctronllable from the MSVC include path options. I edited the #include statement in the openimageio file to one containtg a relative path to fix that.
Cycles runs for me with the CPU device.
Is there a documentation how to build for and use GPUs like CUDA/Optix (do I need both at the same time) and AMD (do I need hip there) without cmake?
There is no documentation on how to build without CMake, if you really want to do that you’d need to look at the relevant CMake code and see the commands it uses for building the kernels. But I would not recommend doing that, replicating it is not simple. You may also be missing out on CPU SIMD optimizations by not using CMake.
