Hello!
Cycles build failed for the master branch on Window with the following error:
LINK : fatal error LNK1181: cannot open input file ‘…\lib\win64_vc15\osl\lib\pugixml.lib’ [D:\Temp\Cycles\cycles\build\src\app\cycles.vcxproj]
Could anyone help me?
[I assume this is about the cycles standalone repro, if this is not the case, please clarify what you are trying to do]
Cycles recently got updated with the blender 2.93 release, you need to update your libraries to use the 2.93 SVN libraries now (previously 2.92)
Yes, cycles standalone repo.
I clone the repo (git://git.blender.org/cycles.git, master branch), then type “make update”. When libraries are downloaded successfully I type “make” and get this error.
I’ll get that sorted out, but that may not be today
Git pull and it should be building again, sorry about that!
Yes, it is building now. Thank you!
Hello!
I’ve got another compilation error with Cycles standalone build and can’t manage it by myself. I hope for you help!
Something is wrong with OSL library. Without OSL it compiles corretly.
Visual studio project files are generated but cycles_osl_shaders.vcxproj contains incorrect data in tag “Command”:
<CustomBuild Include="D:\Work\Cycles\cycles\build\CMakeFiles\48ec45932574b67c81fc315a83e7adbb\node_voronoi_texture.oso.rule">
<Message Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Generating node_voronoi_texture.oso</Message>
<Command Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">setlocal
-q -O2 -I"D:/Work/Cycles/cycles/src/kernel/shaders" -I"" -o D:/Work/Cycles/cycles/build/src/kernel/shaders/node_voronoi_texture.oso
I have the latest version of Visual Studio 2019 and CMake installed. OSL library and other required libraries have been downloaded with ‘make update’.
cmake output:
D:\Work\Cycles\cycles>make
– Building for: Visual Studio 16 2019
– Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.19042.
– The C compiler identification is MSVC 19.29.30037.0
– The CXX compiler identification is MSVC 19.29.30037.0
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Check for working C compiler: C:/MSVS/Community2019/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - skipped
– Detecting C compile features
– Detecting C compile features - done
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: C:/MSVS/Community2019/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
– Found OpenGL: opengl32
– Found OpenImageIO: optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/openimageio/lib/OpenImageIO.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/openimageio/lib/OpenImageIO_Util.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/openimageio/lib/OpenImageIO_d.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/openimageio/lib/OpenImageIO_Util_d.lib
– Found PugiXML: D:/Work/Cycles/lib/win64_vc15/pugixml/lib/pugixml.lib
– Found JPEG: D:/Work/Cycles/lib/win64_vc15/jpeg/lib/libjpeg.lib (found version “80”)
– Found OpenJPEG: D:/Work/Cycles/cycles/…/lib/win64_vc15/openjpeg/lib/openjp2.lib
– Found TIFF: D:/Work/Cycles/lib/win64_vc15/tiff/lib/libtiff.lib (found version “4.1.0”)
– Found ZLIB: D:/Work/Cycles/cycles/…/lib/win64_vc15/zlib/lib/libz_st.lib (found version “1.2.11”)
– Found PNG: D:/Work/Cycles/lib/win64_vc15/png/lib/libpng.lib (found version “1.6.37”)
– #define OPENEXR_VERSION_STRING “2.5.5”
– Found OpenEXR: optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/Half_s.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/Half_s_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/Iex_s.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/Iex_s_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/IlmImf_s.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/IlmImf_s_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/IlmThread_s.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/IlmThread_s_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/Imath_s.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/openexr/lib/Imath_s_d.lib
– Found OpenColorIO: D:/Work/Cycles/lib/win64_vc15/opencolorio/lib/OpenColorIO.lib;D:/Work/Cycles/lib/win64_vc15/opencolorio/lib/pystring.lib (found version “2.0.0”)
– Looking for pthread.h
– Looking for pthread.h - not found
– Found Threads: TRUE
– Found Boost: D:/Work/Cycles/lib/win64_vc15/boost/include (found suitable version “1.73.0”, minimum required is “1.48”) found components: filesystem regex system thread date_time wave chrono atomic serialization
– Found Embree: optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/embree3.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/embree3_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/embree_sse42.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/embree_sse42_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/embree_avx.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/embree_avx_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/embree_avx2.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/embree_avx2_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/lexers.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/lexers_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/math.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/math_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/simd.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/simd_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/sys.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/sys_d.lib;optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/tasking.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/embree/lib/tasking_d.lib (Required is at least version “3.8.0”)
– Found OpenSubdiv: D:/Work/Cycles/lib/win64_vc15/opensubdiv/lib/osdGPU.lib;D:/Work/Cycles/lib/win64_vc15/opensubdiv/lib/osdCPU.lib
– Found OpenMP_C: -openmp (found version “2.0”)
– Found OpenMP_CXX: -openmp (found version “2.0”)
– Found OpenMP: TRUE (found version “2.0”)
– Found OpenVDB: optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/openvdb/lib/openvdb.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/openvdb/lib/openvdb_d.lib
– Found Blosc: optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/blosc/lib/libblosc.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/blosc/lib/libblosc_d.lib
– Found OpenImageDenoise: D:/Work/Cycles/lib/win64_vc15/openimagedenoise/lib/openimagedenoise.lib
– Found TBB: optimized;D:/Work/Cycles/cycles/…/lib/win64_vc15/tbb/lib/tbb.lib;debug;D:/Work/Cycles/cycles/…/lib/win64_vc15/tbb/lib/debug/tbb_debug.lib
– Found GLEW: D:/Work/Cycles/cycles/…/lib/win64_vc15/opengl/lib/glew.lib
– Configuring done
– Generating done
– Build files have been written to: D:/Work/Cycles/cycles/build
Microsoft (R) Build Engine version 16.10.1+2fd48ab73 for.NET Framework
(C) Microsoft Corporation. All Rights Reserved.
Checking Build System
Generating node_absorption_volume.oso
“-q” is not recognized as an internal or external command
C:\MSVS\Community2019\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(241,5): error MSB8066: Custom build for ‘D:\Work\Cycles\cycles\build\CMakeFiles\48ec45932574b67c81fc
315a83e7adbb\node_absorption_volume.oso.rule;D:\Work\Cycles\cycles\build\CMakeFiles\48ec45932574b67c81fc315a83e7adbb\node_add_closure.oso.rule;
…skipped…
bb\node_wavelength.oso.rule;D:\Work\Cycles\cycles\build\CMakeFiles\48ec45932574b67c81fc315a83e7adbb\node_white_noise_texture.oso.rule;D:\Work\Cycles\cycles\build\CMakeFiles\48e
c45932574b67c81fc315a83e7adbb\node_wireframe.oso.rule;D:\Work\Cycles\cycles\build\CMakeFiles\fe75ffe090c3447aa15589230e49bb8c\cycles_osl_shaders.rule’ exited with code 9009. [D
:\Work\Cycles\cycles\build\src\kernel\shaders\cycles_osl_shaders.vcxproj]
Looks like it didn’t pickup on oslc.exe
can you validate win64_vc15\osl\bin\oslc.exe
exists in your library folder?
Yes, win64_vc15\osl\bin\oslc.exe
exists.
Can reproduce, will fix.
made some changes, give it another go!
Now it compiles with OSL turned on, but when I turn off OSL in CMakeLists.txt - there is an error in debug build :))))) It is not a big problem for me but maybe you can fix it…
When I type make debug, I get the following error:
pugixml.lib(pugixml.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value
'2' in cycles_standalone.obj [D:\Work\Cycles\cycles\build\src\app\cycles.vcxproj]
pugixml.lib(pugixml.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't mat
ch value 'MDd_DynamicDebug' in cycles_standalone.obj [D:\Work\Cycles\cycles\build\src\app\cycles.vcxproj]
This happens because the debug build uses release version of pugixml library.
Also I have noticed that there are a lot of warnings about EMBREE_STATIC_LIB redefinition, what is very annoying. Possibly, you can remove add_definitions(-DEMBREE_STATIC_LIB) in src/CMakeLists.txt at line 268 because this define is already defined in lib\win64_vc15\embree\include\embree3\rtcore_config.h
cleaned up both, but for the pugi error you may need to start with a new build folder since cmake tends to cache those sorts of things.
I always make a clean build: delete a “build” folder and revert all changes in my local git repository before testing and reporting an error.
Thanks a lot for your help!
