It is great to join to the community.
i have a project and i wonder if it is possible to create a custom UI for blender instead of developing a new software from scratch.
is it possible to do ? do you know anyone that can do it ?
thanks.
thanks.
Welcome to the board.
“Costume UI”?
Do you mean “custom UI”?
If by “is possible”, you mean “does it violate the Laws of Thermodynamics?”, then the answer is no.
If by “is possible” , you mean “will it be super easy, barely an inconvenience?”, then the answer is no.
Based on the requirements you laid out, I suspect you want to create an Add-on.
sounds like he’s looking for application templates ?
Does anyone know if there is an example / minimal base application template to start working from? I’ve looked at the docs and that explains how it works but there’s not a lot of info on how to start building a template from scratch.
