Hey
I have a bit of an odd problem…
I have a threaded process that once finish will push a job/function to queue that is being executed by blender persistent handler :
@persistent
def load_handler(dummy):
bpy.app.timers.register(blenderModuleTest.runFunctions)
def register():
bpy.app.handlers.load_post.append(load_handler)
The runFunction just grabs item from queue and runs it ()
The problem I have is that the function is meant to apply automatic uv to selected meshes. Even tho I can get the selection/etc/etc I end up with many errors. All of them state that I’m in “Wrong context” Some tries resulted in >
geometry.py", line 233, in internalUvSelected
bpy.ops.object.mode_set(mode='EDIT')
File "C:\Program Files\Blender Foundation\Blender 2.83\2.83\scripts\modules\bpy\ops.py", line 201, in __call__
ret = op_call(self.idname_py(), None, kw)
RuntimeError: Operator bpy.ops.object.mode_set.poll() failed, context is incorrect
The path of error above is as follows>
ob.select_set(state=True)
bpy.context.view_layer.objects.active = ob
bpy.ops.mesh.select_all(action='SELECT')
bpy.ops.uv.smart_project()
if I just call uv.smart_project()
I get this lovely error log
Context : {'area': bpy.data.screens['Layout']...Area, 'blend_data': <bpy_struct, BlendData at 0x000002AC1926C3A8>, 'collection': bpy.data.collections['Collection'], 'engine': 'BLENDER_EEVEE', 'evaluated_depsgraph_get': <bpy_func Context.evaluated_depsgraph_get()>, 'gizmo_group': None, 'layer_collection': bpy.data.scenes['Scene']...LayerCollection, 'mode': 'OBJECT', 'preferences': <bpy_struct, Preferences at 0x00007FF761A34BA0>, 'region': bpy.data.screens['Layout']...Region, 'region_data': None, 'scene': bpy.data.scenes['Scene'], 'screen': bpy.data.screens['Layout'], 'space_data': None, 'tool_settings': bpy.data.scenes['Scene'].tool_settings, 'view_layer': bpy.data.scenes['Scene'].view_layers["View Layer"], 'window': bpy.data.window_managers['WinMan']...Window, 'window_manager': bpy.data.window_managers['WinMan'], 'workspace': None}
File "C:\Program Files\Blender Foundation\Blender 2.83\2.83\scripts\startup\bl_operators\uvcalc_smart_project.py", line 1034, in poll
return context.active_object is not None
AttributeError: 'Context' object has no attribute 'active_object'
location: C:\Program Files\Blender Foundation\Blender 2.83\2.83\scripts\modules\bpy\ops.py:201
File "C:\Program Files\Blender Foundation\Blender 2.83\2.83\scripts\startup\bl_operators\uvcalc_smart_project.py", line 1042, in execute
self.stretch_to_bounds,
File "C:\Program Files\Blender Foundation\Blender 2.83\2.83\scripts\startup\bl_operators\uvcalc_smart_project.py", line 746, in main
ob for ob in context.selected_editable_objects
AttributeError: 'Context' object has no attribute 'selected_editable_objects'
Error: Traceback (most recent call last):
File "C:\Program Files\Blender Foundation\Blender 2.83\2.83\scripts\addons\renderManager\blenderMenuGUI.py", line 45, in runInternalFastTimer
executeInternalFastCommands()
File "C:\Insignia\Blender\renderManager\libRM\gui\mainWindow.py", line 829, in executeInternalFastCommands
function[0](function[1]) # [function,[arguments]]
File "C:\Insignia\Blender\renderManager\libRM\geometry\geometry.py", line 236, in internalUvSelected
RuntimeError: Error: Traceback (most recent call last):
I’m out of ideas speend on it weeks now.
How can I get a valid/proper context so that I can apply uv ?
