I have a node tree that I want to move into a node group. The only ways I’ve found to do that is with bpy.ops.node.group_make
or by adding every node individually, connecting them and setting all parameters.
The second option isn’t that great so I’m using the operator.
This works perfectly if I run it in the node editor, but I need to run it from a button in the properties panel. I couldn’t find any good way to do this so I ended up trying to switch the context temporarily. So basically I just set context.area.type = "NODE_EDITOR"
Because that gave an incorrect context error I decided to take a look at the source code. I’m not at all familiar with it and I don’t even really know C, but what I got from it was that it isn’t just looking for the area type but also if space.edit_tree
is set.
To me it seems like the issue here is that when I run area.type = "NODE_EDITOR"
the edit_tree
attribute is None until the operator has finished running which is why the poll is failing.
At this point it seems like there should be a better way to do this, but I’m not familiar with any way of solving this.
Does anyone know how to solve the problem with edit_tree
being None
or even better a good way of creating a node group from an existing tree?
