I have setup my Arcanist (arc)
for dev in window 10 almost correctly. But I 'am issue in installing certificate. What the problem could be.
this is the error / output:
E:\BlenderFoundation\blender-git-dev\blender (master -> origin)
λ arc install-certificate --trace
ARGV "C:\Program Files\Arcanist\arcanist\bin\..\scripts\arcanist.php" "install-certificate" "--trace"
LOAD Loaded "phutil" from "C:\Program Files\Arcanist\libphutil\src".
LOAD Loaded "arcanist" from "C:\Program Files\Arcanist\arcanist\src".
Config: Reading user configuration file "C:\Users\MaqboolSoftPC\AppData\Roaming/.arcrc"...
Config: Did not find system configuration at "C:\ProgramData\Phabricator/Arcanist/config".
Working Copy: Reading .arcconfig from "E:\BlenderFoundation\blender-git-dev\blender/.arcconfig".
Working Copy: Path "E:\BlenderFoundation\blender-git-dev\blender" is part of `git` working copy "E:\BlenderFoundation\blender-git-dev\blender".
Working Copy: Project root is at "E:\BlenderFoundation\blender-git-dev\blender".
Config: Did not find local configuration at "E:\BlenderFoundation\blender-git-dev\blender\.git\arc/config".
CONNECT Connecting to "https://developer.blender.org/api/"...
>>> [0] <conduit> conduit.ping() <bytes = 39>
>>> [1] <http> https://developer.blender.org/api/conduit.ping
<<< [1] <http> 216,596 us
<<< [0] <conduit> 263,787 us
Usage Exception: Failed to connect to server (https://developer.blender.org/api/): [cURL/77] (https://developer.blender.org/api/conduit.ping) <CURLE_SSL_CACERT_BADFILE> The SSL CA Bundles that we tried to use could not be read or are not formatted correctly.
[2019-05-06 07:18:42] EXCEPTION: (ArcanistUsageException) Failed to connect to server (https://developer.blender.org/api/): [cURL/77] (https://developer.blender.org/api/conduit.ping) <CURLE_SSL_CACERT_BADFILE> The SSL CA Bundles that we tried to use could not be read or are not formatted correctly. at [<arcanist>\src\workflow\ArcanistInstallCertificateWorkflow.php:69]
arcanist(), phutil()
#0 ArcanistInstallCertificateWorkflow::run() called at [<arcanist>\scripts\arcanist.php:394]
I very need it. I have search the problem everywhere but could not find any useful info. If any one have experience, I will be glade to here from you. thanks in advanced
